December 30, 2025, 11:38:43 PM *
Author Topic: is this normal?  (Read 2367 times)
bambam625
« on: April 17, 2020, 12:04:10 PM »
hey fellas,
just recently bought a honda valkyrie. She seems to have a bit of trouble starting the first time of the day, sometimes to the point to where itll kill the battery. Tried running some techron through her, and some seafoam but it didnt make a difference, battery is in good condition, and i keep it on the tender.
Once the bike has been started and ran for awhile, any other attempts to start the bike same day seem alright.
Anyway, I was looking to see if i could see any cracked vacuum lines, or if i could see anything loose and i noticed this. I am a mechanic noob, and am slowly trying to learn. But are these lines being cut normal? Looks way off to me. there are 3 of them cut
https://ibb.co/7CXFN0S
https://ibb.co/2tY7XsJ
« Last Edit: April 17, 2020, 12:21:59 PM by bambam625 » Logged
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: April 17, 2020, 12:17:48 PM »
hey fellas,
Sounds like you aren't using the enrichener lever correctly.
bambam625
« Reply #2 on: April 17, 2020, 12:19:09 PM »
hey fellas,
ive used the choke, and also seen other people had luck doing a slight pull of the throttle , without choke on to get fuel into the carbs, then holding it for a bit, then letting off and turning choke on til it warms up.
my post is mostly about the cut lines i took pictures of
« Reply #3 on: April 17, 2020, 12:24:01 PM »
What Valker is telling you is the “choke” lever on most of these bikes is unusually stiff. You may think you are using it, but it likely has more to go. (Your pics looked normal to me) those are capped vacuum nipples for synching the carbs.
bambam625
« Reply #4 on: April 17, 2020, 12:24:45 PM »
yea i know to push it all the way down, im aware of how stiff it is. so cut lines there are normal?
« Reply #5 on: April 17, 2020, 12:28:07 PM »
If by “cut lines” you mean the short capped off hose on the back of the intake manifolds. Yeah that’s normal. They may very well be cracked and needing replaced though.
bambam625
« Reply #6 on: April 17, 2020, 12:29:27 PM »
ok thats what i needed to know. thanks.
« Reply #7 on: April 17, 2020, 12:47:05 PM »
Below the vacuum plug, I see stains on the engine block. This usually Indicates the intake O rings being bad. Easy to change.
bambam625
« Reply #8 on: April 17, 2020, 12:57:14 PM »
yea i believe the previous owner had a lot of work done to it. On the receipts  i do remember seeing something about replacing those.
rug_burn
Brea, CA
« Reply #9 on: April 17, 2020, 04:39:12 PM »
    You might want to use an American, inch size -122 o-ring, Nitrile material, on that intake tubes-to-head joint, which fills up the space more than the stock unit, and never will leak up until the time it gets rock hard with age.
     Is that a stray screw from somewhere else I see sitting there on the engine, BTW?
« Last Edit: April 17, 2020, 04:41:10 PM by rug_burn » Logged
...insert hip saying here..
« Reply #10 on: April 17, 2020, 05:12:53 PM »
For the record, I still think Valker is probably right. I had my Standard for 6 months before I realized I wasn't using the "choke" to its full extent. If you remove the chrome covers over the carb linkage you should be able to see if there is more left.
bambam625
« Reply #11 on: April 17, 2020, 05:16:17 PM »
i can take a look at it, thanks for the tip.
bambam625
« Reply #12 on: April 17, 2020, 05:17:07 PM »
yes i saw that, i went through and couldnt figure out where it came from, things seem to be in order.
« Reply #13 on: April 17, 2020, 05:21:20 PM »
it looks like one of the bolts on an Interstate pod. Is your bike a Standard or Interstate ?
bambam625
« Reply #14 on: April 18, 2020, 10:53:26 AM »
mine is an interstate. and I have no idea what an interstate pod is. (im slowly learning, bear with me)
« Last Edit: April 18, 2020, 10:56:37 AM by bambam625 » Logged
Savage
United States
« Reply #15 on: April 18, 2020, 11:48:59 AM »
Post some pictures showing your whole bike for us!
That will help us because we can get some visual information regarding what mods may have been done to your Interstate!
Columbia, South Carolina
dpcarson
Lillington, NC
« Reply #16 on: April 18, 2020, 11:56:35 AM »
That Allen screw in the picture is from one of the radiator pods on either side of the radiator on that interstate.  I am guess if it fell in there it probably came out of the top of one of the pods.  There is one on the top of each of the pods that are one of the three that hold each pod on.  I would look at each of those to see if either is missing.
bambam625
« Reply #17 on: April 18, 2020, 12:52:44 PM »
ah yes. i just took the pods off trying to find out where the wiring is for the horn (didnt work when i bought it, trying to replace with denali sound bomb)
bambam625
« Reply #18 on: April 18, 2020, 12:54:18 PM »
this was after i detailed her for the first time.
klb
Hickory nc
« Reply #19 on: April 18, 2020, 12:56:23 PM »
Here is my 99 Standard right after starting it showing how
the Enrichment lever does nothing until you go past where
it gets real hard to keep going. Almost seems like it is not
suppose to go past there but it does.
https://youtu.be/nlKCfEVNwXQ
bambam625
« Reply #20 on: April 18, 2020, 01:00:59 PM »
yea i push it down that far. I figured that out the first time i tried to use it and it did nothing until i pushed it down further.
klb
Hickory nc
« Reply #21 on: April 18, 2020, 01:04:48 PM »
 cooldude  Nice bike.
bambam625
« Reply #22 on: April 18, 2020, 01:08:20 PM »
cooldude  Nice bike.
thanks bud. you can tell the previous owner definitely rode her, she has 100k miles on her, and theres a few spots the paint is worn on the bags and trunk, otherwise shes in good shape. she just needs a good deep solid clean. I took her apart and spent six hours cleaning her, and barely scratched the surface of what needed to be done. washed twice, polished and waxed. ill need to go through her a few more times before she is where I want her.
« Reply #23 on: April 18, 2020, 01:58:43 PM »
cooldude  Nice bike.
100k on these bikes ain’t nothing.  Smiley
bambam625
« Reply #24 on: April 18, 2020, 02:33:23 PM »
cooldude  Nice bike.
yea i know, thats why i got it lol. i saw a thread from like 2013 with people claiming 600k on their bikes, wonder how those bikes are now.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #25 on: April 18, 2020, 03:15:59 PM »
Probably out on the road........ Grin
bambam625
« Reply #26 on: April 18, 2020, 06:17:47 PM »
i told my coworkers about the mileage these can get and they all acted like i was stupid for believing it. I was like whatever.
« Reply #27 on: April 18, 2020, 06:56:08 PM »
On the General Board is our high mileage Valkyrie thread.  Link to High Mileage Valkyrie Thread
« Reply #28 on: April 24, 2020, 07:20:59 PM »
hey fellas,
Only problem with that is....it doesn't. These carbs don't have an accelerator pump so before trying to start the motor, if you give the throttle a twist all you've done is exercise your wrist....nothing more. It won't squirt fuel into the carb throat like you see on an automotive carb with a pump. And it won't put any more fuel in the carbs than the float allows so is a waste of effort. As for leaving the choke on long enough for the motor to warm up also wastes fuel and can possibly cause bluing of the headers. If I ever use the choke it's usually only for a few seconds, enough to get the bike running for a very short time, after which it will start to surge if I don't cut off the choke. On mine it's usually 15-20 seconds before I cut it back or off.
