November 13, 2025, 06:50:13 AM *
Author Topic: idiot light replacement  (Read 1155 times)
bambam625
« on: April 17, 2020, 12:06:55 PM »
hey there,
I have a burnt out overheat light on my honda 2000 valkyrie interstate. I have a spare , but I was wondering if there was a guide on how to replace it, in the manual I didnt see anything about that.
thanks
« Reply #1 on: April 17, 2020, 08:16:09 PM »
Owners or Service manual?
To the best of my knowledge only the lighting is replaceable.
I would check the service manual.
http://valkyrienorway.com/download.html
PDF and a hard copy. Nothing like having both.
F6Dave
« Reply #2 on: April 18, 2020, 04:29:48 AM »
Are you certain the light is out? Could it be the sender?
VALK0316
DELTONA,FL
« Reply #3 on: April 18, 2020, 10:46:03 AM »
I just had my cluster out because I wanted to replace the idiot light and turn signal bulbs with brighter leds...that's when i discovered that the bulbs are soldered in to the circuit board...there are 4 replaceable bulbs in the cluster but they are for instrument back lighting.  you can verify a blown bulb by pulling the connector off the temp switch and putting it direct to ground with the ignition switch in the on position...hope this helps
The journey of a thousand begins...when you release the clutch Smiley...Its not the destination, its the ride!!!
bambam625
« Reply #4 on: April 18, 2020, 10:52:51 AM »
ill check that when i get the chance. if i recall correctly the interstate model, 2000 valkyrie, the light is supposed to turn on for a sec when you start the bike correct? I know the older ones done do this
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: April 18, 2020, 06:24:54 PM »
The non replaceable bulbs in the speedometer pod, I belive are led's.
2001 black interstate
2003 Jupiter Orange wing
sdv003
Prescott Valley, AZ
« Reply #6 on: April 23, 2020, 06:37:47 AM »
The older ones may have lit the LED for a sec or 2 at startup, but I've read a number of threads where that particular lamp does not light.  It does not light on my 98 tourer at startup.  I know it works, as it will flicker on occasion at a stoplight when its 115* outside.
