November 13, 2025, 07:04:40 AM *
Author Topic: aftermarket front rotors?  (Read 1572 times)
Tfrank59
'98 Tourer
Western Washington
« on: April 21, 2020, 09:48:55 AM »
which brand(s) have you had good luck with?  Those who'll only buy OEM, why?  my oems are down to like 3.5 mil.   Time (ok past time) to replace them with now near 90k on them.  I replaced the rear rotor a couple years ago with the EBC brand which seems to be doing okay.
-Tom
« Reply #1 on: April 21, 2020, 10:32:07 AM »
Sometime ago, I remember reading on here that more recent (but maybe not the brand new) Gold Wing front rotors would fit.  They were thinner than, but still rated for the same life as Valk OE rotors.  They were apparently a good deal cheaper than OE rotors, but I do not know if that's still true.
Can't speak to aftermarket, other than I remember reading if you get EBC (or other) rotors, you should use their pads too.
Just recollections.
Ken aka Oil Burner
Mendon, MA
« Reply #2 on: April 21, 2020, 11:37:29 AM »
Some interesting reading on rotors: http://www.valkyrieforum.com/bbs/index.php/topic,107950.0.html
Bagger John - #3785
« Reply #3 on: April 21, 2020, 11:38:28 AM »
I'm looking for a set of front rotors with black carriers for a project. What's out there?
Jruby38
Oxford Mass.
« Reply #4 on: April 21, 2020, 01:24:09 PM »
I had the same problem with OEM pads gouging the rotors. Went with GW fronts and aftermarket kevlar  pads. These pad stop better, are less money, and shine the rotors to look like chrome.  Win Win.
Tfrank59
'98 Tourer
Western Washington
« Reply #5 on: April 21, 2020, 03:11:07 PM »
Pretty funny cuz I started that thread last summer. I was at the time thinking about buying a front wheel off a guys Interstate that had good rotors but it didn't work out so now I'm stuck buying just rotors. And as I said I'm overdue. I think Goldwing rotors are actually thinner than valk rotors even though they work okay. I seem to recall that somewhere.
-Tom
« Reply #6 on: April 21, 2020, 03:43:06 PM »
Brake Rotors
The following are Honda part number from a GL1800 GoldWing. They do fit a Valkyrie.  Front only
DISK, R. FR. BRAKE
45120-MCA-003
DISK, L. FR. BRAKE
45220-MCA-003
Print and laminate this for your saddlebag.
https://www.jkozloski.com/generic_parts.htm
Ken aka Oil Burner
Mendon, MA
« Reply #7 on: April 21, 2020, 06:00:03 PM »
Haha. I didn't even notice that it was your thread. LOL I just remembered that Goldwing and VFR rotors were mentioned somewhere and searched VFR. Well, I hope it refreshed your memory if nothing else  Grin
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: April 22, 2020, 07:27:46 AM »
[/quote]
 Thanks for that link!
-Tom
Tfrank59
'98 Tourer
Western Washington
« Reply #9 on: April 22, 2020, 04:01:52 PM »
Going to hijack my own thread here haha does anybody know offhand what a brand new OEM front rotor for a valkyrie measures? Is it like 5.5 mm thick?
-Tom
« Reply #10 on: April 22, 2020, 04:48:06 PM »
Thick? I think it was 7mm. I know the mine thickness is printed, I'm sure that's 4mm.
Tfrank59
'98 Tourer
Western Washington
« Reply #11 on: April 22, 2020, 05:28:49 PM »
Gordon, naw, wouldn't be 7mm to start for fronts. I'm thinking fronts start at 5 (or 5.5?) new so you only get 1mm till you're done--that's like .039", not too bad.  Reason I bring it up is I am looking at some used OEMs and want to know where they were when new, as the seller will show me with calipers where they are now.
UPDATE: Okay, I answered my question about the original thickness of front rotors (OEM) by measuring the outside rim of mine, in the area which isn't worn--it's exactly 5mm.
« Last Edit: April 22, 2020, 07:31:42 PM by Tfrank59 » Logged
-Tom
« Reply #12 on: April 23, 2020, 06:23:15 PM »
Wow, I was sure of that. Maybe the rear?
Checked out ebay. They like listing the thickness. All used.
Front
Valk 4mm min, thickness 4.7mm, so 5mm looks reasonable.
GW 5mm min, thickness 5.53, so looks like 6mm.
Rear
Valk 5mm min, thickness was 7.5, was it measured wrong?
GW no min seen, but I found one at 6.5mm thick.
mello dude
Dayton Ohio
« Reply #13 on: April 23, 2020, 08:06:41 PM »
You guys perked my curiosity as I have brand spankn new Gold Wing front rotors to go on my standard.
So the caliper come out and the magic numbers are....
4.53
4.58
4.49
4.52
Ok they are 4.5mm...
 Cool
