March 30, 2026, 01:11:21 PM *
Author Topic: power port  (Read 2097 times)
N0tac0p
« on: April 22, 2020, 09:10:45 AM »
not sure which one i'll buy, but wondering where's the best place to wire it to?
rug_burn
Brea, CA
« Reply #1 on: April 22, 2020, 09:18:41 AM »
   Yeah:  that's a good question!   Come to think of it, I've never seen the Valk's fuse panel, if it has one.
  I suppose that's a good commentary on the reliability of the bikes:   never had to fix anything there in 182,000 miles.
   I was thinking about the same thing, too.   It would be nice to not have to go directly to the battery, even to have a stock fuse position on the panel.   I'll check that-
« Last Edit: April 22, 2020, 09:26:13 AM by rug_burn » Logged
...insert hip saying here..
« Reply #2 on: April 22, 2020, 09:24:55 AM »
I would run an inline fused power supply connected directly to the battery with a relay controlled by the switched accessory lead.
N0tac0p
« Reply #3 on: April 22, 2020, 09:47:19 AM »
switched accessory lead from the key switch?
« Reply #4 on: April 22, 2020, 10:07:53 AM »
One of these is the best way to go. There are others cheaper.
https://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
« Reply #5 on: April 22, 2020, 11:40:25 AM »
There are 2 accessory leads (female bullet connections) usually located under the right side cover in front of the battery box.  They may or may not have something connected to them depending on whether any modifications were made to the bike.  One of these leads is Hot all the time (I believe, could be hot while key off, I can't recall for sure), the other is hot when ignition is on.  The function can be checked with a test light or multimeter.  The coil of a relay can be wire to one of these leads to control power to a direct line from the B+ to your aux fuse block.
Fazer
« Reply #6 on: April 22, 2020, 01:03:34 PM »
+1 on the Eastern Beaver.  I had a cheap unit until it shorted out and my dan marc quit working, stranding me.
Nothing in moderation...
rug_burn
Brea, CA
« Reply #7 on: April 22, 2020, 02:13:48 PM »
So we got two wires there in front of the battery-  But which one is best?
    You got the one always hot, which is good if you want to be able to charge your cell phone or whatever while you're having dinner, in the bar, etc, or just parked.  But if you leave it connected for a long time, and forget, it can drain the battery... maybe.
    Then you got the one where it's only on when the key's in and turned.   But that kind of makes it a little inconvenient, doesn't it?
    If you're installing a 5 volt USB port, even a 2 amp outlet gives you about 10 watts at full 2 amp rating, which doesn't happen too long when charging a phone, but with other stuff, it could.   And then the power consumed from the battery will be a little higher, since nothing gives you 100% efficiency.
   Maybe what's needed is a timer or device to cut off the port?    I'd just hate to have to push start my Valk... (again)
Jersey
VRCC #37540
Southern Maryland
« Reply #8 on: April 22, 2020, 02:32:42 PM »
+1 on the easternbeaver as well.  I don't have one, but know this is good quality. Plus it takes all the guess work out.
If you just want to add ONE power switch, then you buy the parts to make one of their 50A Relay Kit ‘Shorty’ setups... basically a single relay triggered by the key on.
Jersey
« Reply #9 on: April 22, 2020, 04:46:08 PM »
I take it you are referring to a USB or aux plug port, to have power to ?
As already mentioned, what ever it is, it must have a fuse. All I've ever seen, all come with a fuse.
Next question is how do you want it to behave. Always on (I did), add a switch (like ChrisJ?) or via the ignition (switched) power?
I didn't worry about always on, because there was times I wanted to be able to leave something on the bike charging. Then where I had it (GW front pouch/trunk) wasn't noticeable. I also had one mounted external, which was highly visible, so I wouldn't leave things plugged in (air compressors, etc.) and I also didn't worry about continues (fused) power. A lot easier to install too.  Smiley
CoreyP
Bluffton, SC
« Reply #10 on: April 22, 2020, 07:05:53 PM »
Thanks that's useful info. I spotted the 2 accessory leads and was wonder what they are for, now I know that they can be use for.
Jims99
Ormond Beach Fl.
« Reply #11 on: April 23, 2020, 07:03:31 AM »
I put one on both mine and have them on a switch. The tourer is on a switch with the Bluetooth speakers and mounted next to key. The interstate is on a switch mounted on dash and considering adding the radio to the same switch. The power ports I got have a built in battery display. You can easily check charging and voltage.  I see no need for a relay, draw very little power.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
