January 30, 2026, 05:03:16 AM *
Author Topic: Changed the Rake on an Interstate  (Read 3340 times)
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« on: December 13, 2009, 10:15:43 PM »
I have started a rebuild of a 99IS.
Yesterday I read of someone converting to a trike, then changing the rake by 4.5 degrees.
Has anyone done this without the trike conversion?
I like the idea of lowering the bike a smidge this way, but am concerned about handling.
If you have made this mod, I'm really interested in what you think about the handling & braking. As well, how much lower did the front end go down?
Best regards,
Glenn Schentag
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« Reply #1 on: December 14, 2009, 12:29:59 AM »
Check out Daryl at this link.
http://xf6-custom.com/
I have a set of 6 degree raked triple trees on order now.  He has some very happy customers on the board.
Tx Bohemian
Victoria, Tx
« Reply #2 on: December 14, 2009, 05:49:17 AM »
...then changing the rake by 4.5 degrees...
I take it this means your changing the caster angle, right?
Is this an increase or decrease of the angle?
Al
GJS
« Reply #3 on: December 14, 2009, 08:39:34 AM »
I checked the site. The bikes look good, especially the 8degree Valk.
Makes me wonder about being able to aim the headlights properly on the Interstate.
I wonder if I have enough room to adjust the incremental 8 degrees or whether I should try the six.
Why did you choose 6 over 8?
Cheers,
Glenn
- W. M. Lewis
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #4 on: December 14, 2009, 09:37:59 AM »
If you have questions, just give Daryl a call...  He knows this stuff inside and out, and when you call the number on his web site, he is the one that answers the phone.  XF6 is a small operation, but there is no place else on the planet that knows more about the Valk, and how Triple Trees  improve/change the numbers...
Yep, he's a good friend of mine, but he's also the best at what he does.
Black Dog
Don't you know...
roboto65
Conroe,TX
« Reply #5 on: December 14, 2009, 10:39:19 AM »
+1 on what Blackdog said I have his shock bushings and talked to him for a while great guy and loves to talk Motorcycle and Stands behind all he makes!!!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
MP
North Dakota
« Reply #6 on: December 14, 2009, 11:17:17 AM »
+1 on Darrell.  He is a great guy to work with.
MP
"Ridin' with Cycho"
RUDE DOG - Steelers
« Reply #7 on: December 14, 2009, 11:42:40 AM »
Hey Glenn,
I ordered the 6 degree which is what is suggested.  The 8 degree is for Trikes.  Im also having mine Black Chrome powdercoated.  I cant wait to get these.
GJS
« Reply #8 on: December 23, 2009, 12:41:04 PM »
Well, I just ordered a set the 6 Degree Triple Tree with the 1"3/8 extentions.
Now I need to lower the rear end with Progressive 412s or 430s.
Anyone used anything different?
Is it possible/practical to lower the bike using air shocks?
Daryl was a very informative fellow.
Glenn
- W. M. Lewis
RUDE DOG - Steelers
« Reply #9 on: December 23, 2009, 12:51:12 PM »
If you went with the extensions, how come your trying to lower the rear?  Im not using the extensions and I have Progressive 430's at 11.5 inches.  Daryl said that setup is what he runs and it is a perfect match. From what I understand, the extensions basically bring the front end of the bike back to the stock height after the rake.  So if you are going to go with a shorter rear shock, I would think it would make sense not to use the extensions.  I could be wrong but that was my understanding.
GJS
« Reply #10 on: January 01, 2010, 10:09:56 PM »
Tx Bohemian: Sorry I missed your question earlier.
I think I am increasing the angle by six degrees, as the standard config is not at 90 degrees. I have assumed that six degrees is a relative measurement to stock.
Steelers: I have ordered a set of 11.5" 412s. I too think I might just try without the extensions. I'll give Daryl a call and ask why the difference in recommendations.
Best of the new year to everyone!
Cheers,
Glenn
- W. M. Lewis
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #11 on: January 02, 2010, 06:51:41 AM »
I also am planning on the 6 degree and when I talked to Darryl, he said that I should also consider going to 11.5 shocks to balance the front end change. That was good news because I already have 11.5 412's. After I put on the 11.5 shocks I could definitely notice a difference in handling when I get off of my stock Interstate and on to my 11.5 Standard, when I make a quick turn there is a tendancy for the bike to want to go wide. Something you might not notice so much and wouldn't be a problem when you are used to it,only a problem when you go from one to the other. I am a believer that the 6 degree and 11.5 shocks are important to maintain the original geometry or as Daryl said, actually improve the low speed handling.
