December 31, 2025, 01:03:42 AM *
Author Topic: Mounting Tires With Zip Ties  (Read 1262 times)
F6Dave
« on: April 27, 2020, 09:44:33 AM »
Has anyone mounted tires using zip ties to hold the beads close together?  I stumbled onto a video showing the technique, and it appeared to make the job much easier.
« Reply #1 on: April 27, 2020, 12:09:26 PM »
I tried it. Valkyrie tires are bigger than the little bicycle tires
that guy on youtube was putting on his crotch rocket...  Wink
http://www.valkyrieforum.com/bbs/index.php/topic,19676.0.html
I use the "little man down at the Suzuki shop" method now  cooldude ...
« Reply #2 on: April 27, 2020, 01:07:26 PM »
Have seen it done with simple packing tape. On an Austone Taxi Tire.
Squeezed the bead together in about 6-7 places around the tire and put a piece of tape on bead next to clamp. Tire went on pretty slick once on pull up the tape out.
VALK0316
DELTONA,FL
« Reply #3 on: April 27, 2020, 06:46:59 PM »
I just did the front tire on my Interstate with zip ties...use them to remove the old tire and to mount the new Dunlop...easiest tire swap I've ever done...having lots of sunshine to warm up the ties definitely helped.
The journey of a thousand begins...when you release the clutch Smiley...Its not the destination, its the ride!!!
