December 30, 2025, 11:22:11 PM
Pingel leaking - quick question - FIxed
Topic: Pingel leaking - quick question - FIxed (Read 1130 times)
Lyle Laun
Calgary, Ab
April 28, 2020, 08:32:16 PM »
Folks:
I've swapped fuel tanks and have a small leak at the Pingel petcock (not sure where yet). I will pull the tank and check it out tomorrow. A couple of quick questions - I'm reading online to use 3 wraps of thread tape before installing the valve, Is this correct ? Any better suggestions ?
Assume the leak is at the threads but have any of you ever failed the internal o-rings and needed to replace these ?
Thanks in Advance
Lyle
Last Edit: April 29, 2020, 01:02:09 PM by Lyle Laun
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
Re: Pingel leaking - quick question
April 29, 2020, 06:25:36 AM »
I have the standard OEM petcock on my Interstate and I have had it on and off many times and never had a leak or used any thread sealing tape.
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
April 29, 2020, 06:27:39 AM »
The bung on the Valkyrie tank is not a pipe thread.
No tape is needed.
h13man
Indiana NW Central Flatlands
April 29, 2020, 06:49:42 AM »
I had mine off while the tank was being repainted. I don't use thread sealant tape on anything having to do with liquid especially fuel/solvents involved. I reinstalled mine with nothing. The only issue I had was getting the valve "clocked" into position. Over tightening O'rings can cause failure also.
Gondul
VRCC #408
Central Florida
April 29, 2020, 08:52:37 AM »
Never used pipe tape either... if the Pingel itself is leaking, send it back and they will repair (or replace) for a really low price. I sent them my old Pingel that was leaking badly due to sitting...they simply sent me a brand new one.
http://www.pingelonline.com/content/fuel-valve-rebuild.asp
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
Lyle Laun
Calgary, Ab
April 29, 2020, 01:01:05 PM »
Thanks Everyone, got it sorted out. It isn’t a factory tank and just needed the threads and seats cleaned up a bit better than what I Did on the first install.
Appreciate the good advice
Lyle
Get out & Ride !!
=> InZane XXV
