theredark
« on: May 10, 2020, 06:46:37 AM » |
Good morning all, can someone tell me if there is enough space between inner and outer shells of trunk? Dont want to disassemble it if it wont fit!
2000 Black/Red Interstate
Jims99
« Reply #1 on: May 10, 2020, 07:16:52 AM » |
There is actually quite a bit of room. Are you talking about the little black box that flashes the brakes. There should be room for that. I should be getting my LED bulbs today, I’ll be pulling lights to change and can measure it for you.
The light at the end of the tunnel, is a train. 99 tourer 00 interstate 97 standard 91 wing 78 trail 70
« Reply #2 on: May 10, 2020, 07:33:08 AM » |
Please elaborate. Is there a LED bulb that fits inside the stock IS trunk lights? If so I guess you'll still have to heat the housings in an oven to crack them open?
Jims99
« Reply #3 on: May 10, 2020, 12:18:30 PM » |
there is 3.5” X 6” of space between lights plus space around them. Pull the right light out, that’s the side the wire harness enters. You can do the hookup all through the light opening.
Jims99
« Reply #4 on: May 10, 2020, 12:29:22 PM » |
Please elaborate. Is there a LED bulb that fits inside the stock IS trunk lights? If so I guess you'll still have to heat the housings in an oven to crack them open? I ordered replacement bulbs from superbright LEDs. Just replace bulb, no need to separate lens. Going to do one side and see if it’s bright enough. Otherwise they do make the board style lights that will fit if you open lenses to install. Don’t want to go that route if replacements are bright enough. And 85% cheaper. New lights haven’t shown up yet. Also ordered the replacements for headlights for interstate and gauge lights and break light for the tourer.
theredark
« Reply #5 on: May 10, 2020, 01:20:23 PM » |
Thanks for the info!
WoodyFL
« Reply #6 on: May 10, 2020, 01:26:49 PM » |
2000 Blue/Silver I/S Ocoee, FL
Forge
« Reply #7 on: May 10, 2020, 04:35:46 PM » |
I installed mine behind the battery. Much easier.
Jims99
« Reply #8 on: May 10, 2020, 06:47:51 PM » |
thats where I installed mine also. those bulbs are great, used them on another project. I couldn’t use them on mine, I changed my trunk lights to running/ brake/ and turn.
« Reply #9 on: May 11, 2020, 05:44:22 AM » |
Please elaborate. Is there a LED bulb that fits inside the stock IS trunk lights? If so I guess you'll still have to heat the housings in an oven to crack them open? I ordered replacement bulbs from superbright LEDs. Just replace bulb, no need to separate lens. Going to do one side and see if it’s bright enough. Otherwise they do make the board style lights that will fit if you open lenses to install. Don’t want to go that route if replacements are bright enough. And 85% cheaper. New lights haven’t shown up yet. Also ordered the replacements for headlights for interstate and gauge lights and break light for the tourer. Thanks, I'll look into this! Which bulbs did you order? I want to go the running/brake/turn route as well. The wiring is already set up this way for the now smashed BonS lights, so the transition might be fairly easy. (Sorry for hijack, I'll try PM)
« Last Edit: May 11, 2020, 03:54:17 PM by Valkorado »
h13man
Indiana NW Central Flatlands
« Reply #10 on: May 11, 2020, 07:34:49 AM » |
I don't know if a Interstate is is designed like the standard, but I mounted mine on the fender above frame brace area under the seat. Close to the wires that you need to splice into and offers good protection from the elements.
« Last Edit: May 11, 2020, 07:36:54 AM by h13man »
Gondul
VRCC #408
Central Florida
« Reply #11 on: May 12, 2020, 05:13:02 AM » |
As the Government of the United States of America is not, in any sense, founded on the Christian religion.... John Adams - 1797
Because Thou lovest the Burning-ground, I have made a Burning-ground of my heart That Thou, Dark One, hunter of the Burning-ground, Mayest dance Thy eternal dance.
Jims99
« Reply #12 on: May 12, 2020, 05:37:46 AM » |
I ordered 7443-R27-T-CK for the main lights and the 74-RHP3 for the smaller lights. Superbright LEDs Both fit right in perfectly but not as bright as I thought. Definitely brighter than stock and react to the brake and turn faster (not the fade on and off of stock) I ordered the red LEDs and may try white to see if that’s brighter. Has anyone used white in their red lenses? I was told it’s not the same as stock white. Thanks
WoodyFL
« Reply #13 on: May 12, 2020, 05:43:22 AM » |
I tried white LED's at first and they gave an orange tint to the rear lenses. Went to red and looks much better.
Jims99
« Reply #14 on: May 12, 2020, 03:54:53 PM » |
Thanks. That’s what I heard through the grapevine, nice to hear from someone who has first hand knowledge.
« Reply #15 on: May 12, 2020, 05:24:26 PM » |
Jim are the 74-RHP3 mini wedge bulbs? If so, are minis all that will fit in the smaller light housings? I'd prefer to use full size wedge if it'll fit.
Jims99
« Reply #16 on: May 13, 2020, 05:14:41 AM » |
Jim are the 74-RHP3 mini wedge bulbs? If so, are minis all that will fit in the smaller light housings? I'd prefer to use full size wedge if it'll fit. Yes. Don’t think you’ll get anything bigger in there. The socket and the hole it fits are very small.
