November 13, 2025, 04:54:32 AM *
Author Topic: Led turn signals  (Read 1342 times)
Champ_sappi
« on: May 11, 2020, 05:40:28 PM »
Is there a led bulb I can directly replace the stock ones in the front or does anyone know the stock bulb that comes in it
RonW
Newport Beach
« Reply #1 on: May 11, 2020, 09:12:38 PM »
1157 (dual filament)
2000 Valkyrie Tourer
« Reply #2 on: May 11, 2020, 09:44:13 PM »
Get yourself a LED flasher similar to this and switch out your OEM one from under your left side panel. Much better than resistors, and won't get hot.
Chart here shows Valkyrie 1500 compatability (it does fit all models and years, although that is not stated).
https://www.ebay.com/itm/2-Pin-Electronic-LED-Flasher-Relay-Fix-Motorcycle-Turn-Signal-Lights-Hyper-Flash/222242213074?fits=Model%3AValkyrie+1500%7CMake%3AHonda&epid=1983423826&hash=item33beab0cd2:g:HZ0AAOSwgmJXz72V
Same thing,  but ships from USA.
https://www.ebay.com/itm/2-Pin-Electronic-LED-Flasher-Relay-w-Adapter-Fix-Hyper-Flash-Turn-Signal-Bulbs/381103167749?hash=item58bb84d905:g:VMoAAOSw2H1drzHt&vxp=mtr
2 pin works great on our Valkyries.  Direct replacement, plug and play with no hard wiring necessary.  I have one in both my bikes, with LED turns front and back.
« Last Edit: May 11, 2020, 10:11:25 PM by Valkorado » Logged
Gondul
VRCC #408
Central Florida
« Reply #3 on: May 12, 2020, 05:06:53 AM »
Picked up everything I needed through SuperBrightLEDs...great folks to deal with and easy/no hassle replacements if there is an issue, I even picked up some base sockets to retro-fit the lights on the truck I got to brake/signal..
Diode
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/metric-bike-diode-kit/1190/2805/
LED Flasher
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/electronic-led-flasher-relays-for-motorcycle/787/842/
Wedges for the indicator bulbs in the bucket
https://www.superbrightleds.com/moreinfo/miniature-and-subminiature-bulbs/74-led-bulb-1-smd-led-miniature-wedge-retrofit-car/227/7256/
1156 Amber
https://www.superbrightleds.com/moreinfo/miniature-and-subminiature-bulbs/1156-boat-and-rv-led-light-bulb-27-smd-led-tower-ba15s-retrofit-base-420-lumens/2623/12848/
1157 Amber
https://www.superbrightleds.com/moreinfo/miniature-and-subminiature-bulbs/1157-led-bulb-dual-function-27-smd-led-tower-bay15d-bulb/2625/12851/
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
« Reply #4 on: May 12, 2020, 12:41:34 PM »
Pretty sure with the flasher you won't need diodes or resistors for the blinker wiring.  At least neither of my bikes did. Come to think of it, I take that back.  I did use a diode in the headlight bucket along with the flasher on the Tourer to make everything work properly.  One of these.
https://www.kuryakyn.com/products/719/diode-kit
The Interstate did not need a diode.
I'm using switchback LEDs with clear lenses on front with the Bullet.  They work great, and look really sharp with the white LED Cobra spots and LED headlight.  All cool white LED up front, until I turn and the amber kicks in.
Mine look very similar to these.
https://www.ebay.com/itm/2x-1157-Dual-Color-Switchback-White-Amber-Turn-Signal-Led-Light-Bulb-Replacement/261959445052?epid=22013577856&hash=item3cfdffea3c:g:f3MAAOSwLSZb85o6&vxp=mtr&redirect=mobile
« Last Edit: May 13, 2020, 07:18:15 AM by Valkorado » Logged
