November 13, 2025, 08:38:08 AM *
Author Topic: Tunes?  (Read 1260 times)
burple05
Van Buren, Arkansas
« on: May 15, 2020, 09:01:12 AM »
I was thinking of installing some tunes on my 2001 Standard.  What do you all recommend?  Where is the best place to hook system up and hide receiver/amp.  Something that isn't too expensive but still have enough volume and clarity to here it at highway speed.  Appreciate any advise you could give.
thanks , Ron.
It's the same, only different.
vanagon40
Greenwood, IN
« Reply #1 on: May 15, 2020, 09:18:31 AM »
I apologize in advance as this does not directly address your question, but my solution was an ipod and helmet speakers. Of course, this does not work with no helmet or a half helmet. I also have a 2001 Standard and have no idea where to put an amplifier.
flash2002
Montreal, Que
« Reply #2 on: May 15, 2020, 10:26:27 AM »
I got myself one of these, plenty of power on the road. I installed the amp in the saddle bag and ran the wires to the front.
             http://www.sharkmotorcycleaudio.com/index.php?route=product/product&path=59_60&product_id=84
Jruby38
Oxford Mass.
« Reply #3 on: May 15, 2020, 01:16:12 PM »
i installed a kit by Cycle Tunes on my standard. Amp under the seat on top of the tool kit. Fused power to a toggle switch so you can play tunes without bike switch on.
h13man
Indiana NW Central Flatlands
« Reply #4 on: May 16, 2020, 05:48:16 AM »
W/O a windshield?
« Reply #5 on: May 16, 2020, 06:13:01 AM »
My amp needs airflow. It’s there under the triple tree.
« Reply #6 on: May 16, 2020, 06:28:14 AM »
Mine's a little more involved.  Installed a Kenwood 400w amp behind the coolant tank - swapped the ICM over to make more room.  It feeds into a 300w Lanzar crossover with bluetooth on top of the battery, supports & mixes two different input sources and can power subs.  Quality speakers  on the handlebar. Power via PC-8 power panel with relay and 3-pos sw that enables on with ignition, off, or w/o ignition.  With the latter, that's for tunes at a hotel / BBQ etc, must be supported by adding a charger or the battery will drain.
