December 30, 2025, 08:07:29 PM *
Author Topic: throttle play  (Read 1406 times)
lar1620
« on: May 17, 2020, 11:55:59 AM »
I tried to post already but don't know if it went thru ! Yesterday I started having about 1 inch of free play on my throttle. I have a 2001 Valk (standard). My thought is that a main connection at the carbs slipped. I messed with the settings at the handlebars, but it did nothing. If someone can help me I would greatly appreciate it. I also am not sure that I will find the answer you send on this site. Please email me at: mrantioch@hotmail.com ! Thank-you so very much in advance ! Larry
« Reply #1 on: May 17, 2020, 12:15:55 PM »
It should be fairly easy to see if the cables look right at the carbs. If it’s not  looking messed up there I’d suspect a failed cable. They are fairly easy to replace.
« Last Edit: May 18, 2020, 05:40:24 AM by Chrisj CMA » Logged
lar1620
« Reply #2 on: May 18, 2020, 06:18:51 AM »
Thanks for the reply Chris. Would I have to pull the tank and breather box ? I imagine I would. I am going to call my local dealer today and see what they can tell me. Thank-you again !
« Reply #3 on: May 18, 2020, 06:55:44 AM »
Pulling the tank makes it way easier. You won’t need to pull the air box
« Reply #4 on: May 19, 2020, 06:07:43 AM »
Most likely they'll say "Valkyrie?, is that a Honda?"
As Jeff stated, pulling the tank will make it easier and you can check or replace the air filter also.
studlly 64
Norwood, Mass
« Reply #5 on: May 23, 2020, 08:57:58 AM »
I pulled my carbs a couple weeks ago, put everything together, tighten everything, took her for a ride, took me a couple hours while I'm riding to figure out why do I have about an inch of play, I completely forgot to tighten the screws on both cable by the carburetor  tickedoff tickedoff tickedoff
Now I have to pull the tank to adjust.
1998 ST
« Reply #6 on: May 23, 2020, 10:57:09 AM »
Like I always say. If you think pulling the tank is hard, you just haven’t done it enough  Evil
« Reply #7 on: May 23, 2020, 01:43:28 PM »
I hear you Jeff.  I have only pulled mine 6 or so times but never found it difficult.
« Reply #8 on: May 23, 2020, 02:01:50 PM »
I have had bikes and worked on bikes that the tank was harder to pull than the Valkyrie for sure. No body parts to remove, remember the cross over tube what a PITA that is.
I must have pulled a Valkyrie tank 80 or so times. I never found it hard. Now I don’t even think about it. If it needs to come off boom it’s off. Sometimes getting the vacuum line to the petcock is a pain because on some Valkyries more than others for some reason the connection is directly behind a fairly immovable wire harness. Aside from that, POC once you have done it a few times.
