December 30, 2025, 08:07:10 PM *
Author Topic: triple tree swap out and maintenance  (Read 1660 times)
Warlock
Magnolia, Ms
« on: May 21, 2020, 04:38:23 PM »
Did  a little maintenance today. Pulled my 5 degree triple tree off and installed a 6 degree and installed new chrome cobra tire up front. Can't really tell much difference between the 5 and 6 degree.
David
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
« Reply #1 on: May 22, 2020, 04:38:18 AM »
David
Changing from 5 deg. to 6 deg. you will not notice any change when turning. Your arms and shoulders will feel the same amount of resistance. My trike, I installed a 4 deg. triple tree and was disappointed with the amount of change in handling. 20 years ago a 4 deg. rake kit was recommended for a Valkyrie trike and a Goldwing trike got 6 degrees. I would change mine to 6 deg. but the cost and amount of work required is not worth the difference to me.
Greg
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
3W-lonerider
Shippensburg Pa
« Reply #2 on: May 22, 2020, 05:42:47 AM »
David
Greg
when my valkyrie trike was first built by motortrike i kept the stock tree, let me tell you it was like trying to steer a log truck with no power steering. i then bought a 4 degree, there was some relief in the steering and i was quite happy with it till my shoulders were really getting tired after 50 miles. i had very good friends from ny. and canada that purchased a 6 degree out of the goodness of their hearts and i installed it. there was a considerable difference between the 4 and the 6. changing the tree is not alot of work. if i remember correctly it took me 4 hours. but it was well worth it.
Warlock
Magnolia, Ms
« Reply #3 on: May 22, 2020, 11:51:33 AM »
David
Greg
Took me around 4 hrs and that was also changing out a front tire. Wasn't bad at all. Will probably sell my 5 degree triple tree.
David
Jims99
Ormond Beach Fl.
« Reply #4 on: May 22, 2020, 05:39:58 PM »
How would the 5 degree affect the ride of a two wheeler? I’m happy with how my tourer handles but like the looks of the rake.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Warlock
Magnolia, Ms
« Reply #5 on: May 22, 2020, 06:10:16 PM »
I can't say, but have seen several on here with a rake kit. Maybe they will chime in.
David
Avanti
Stoughton, Wisconsin
« Reply #6 on: May 23, 2020, 04:10:23 PM »
I have over 60,000 miles using Daryl's 4 degree Triple Trees.
Comes off the kickstand easily, rides nice, and steers like it has power steering.
It will change the U turn radius slightly and also lower your front end about one half inch.
I suppose there is a sight change in the way the forks react but I have not notice any great change with 4 degree Triple Tree.
I did not do this change without researching it first.
I recommend calling Daryl at VTXtreme, He will be very informative.
This is his contact information as noted on his web page https://vtxtreme.com/contact/
Warlock
Magnolia, Ms
« Reply #7 on: May 23, 2020, 05:34:53 PM »
I know they sell some fork extensions. What I did with mine was install the 1800 Goldwing Progressive springs. Swapped to 7.5 wt oil and put 1.5 less oil than it called for. The springs gave me around 1/2 to 3/4 inch more on travel and the lighter oil relaxed the rebound. I was running 10 wt and removed 1.5 once in each one. Was to me still a little stiff so after changing to the 7.5 and 1.5 oz less in each fork it rides real nice.
David
