December 30, 2025, 08:07:09 PM *
Author Topic: removing baffles  (Read 1785 times)
Spurs
Summerfield, FL
« on: May 24, 2020, 06:58:01 AM »
has anyone ever removed some of the baffles on the OEMs to tweak the sound of the exhaust without going to 6 to 6 cobras
1997 Valk Std
2014 Indian Vintage
2016 Polaris Slingshot
Politicians and diapers need to be changed often and for the same reason. Mark Twain
wingrider02
Maple Lake, MN
« Reply #1 on: May 24, 2020, 07:30:52 AM »
I chopped out the rear baffles on my pipes, and then put truck stacks over the front baffle. Certainly woke up the bark that is known to come out of these bikes.
Spurs
Summerfield, FL
« Reply #2 on: May 24, 2020, 07:34:11 AM »
Thanks, after second thoughts I think I will stay with the OEMs and listen to the purr
1997 Valk Std
2014 Indian Vintage
h13man
Indiana NW Central Flatlands
« Reply #3 on: May 24, 2020, 07:56:09 AM »
My piggies were cut off from original owner and with stock tips they are very annoying @ highway speeds thus 60mph really sucked. Made 12.5" wide open slash cut tips, problem solved though I would like to had it stock form to do my own sound altercations.
« Reply #4 on: May 24, 2020, 09:40:44 AM »
On the home page, do a search for "ragnar cut"
You'll get about a hundred threads to check out.
da prez
Wilmot Wi
« Reply #5 on: May 29, 2020, 06:27:15 AM »
  I made an extension for a hole saw that went inside the exhaust tube. I drilled out one baffle at a time on all six. I started the bike up and checked the sound.  I do not remember how many I cut out , but when I felt the sound was right , I put on truck stacks with 45 degree turn outs.  On a highway with concrete barriers , I get a drone. I think straight pipes would have been better.  I like the sound and it is not obnoxious.
                                             da prez
