December 30, 2025, 08:07:26 PM *
Author Topic: IS sound system questions  (Read 1095 times)
txtriathlete
« on: June 01, 2020, 11:57:02 AM »
Front speakers quit playing, not sure why. Nothing new going on. Swapped out speakers a while back for polks, they had been working fine. Connections are tight, fader should allow speakers to play but no sound.
Thoughts?
Ramie
2001 I/S St. Michael MN
« Reply #1 on: June 01, 2020, 09:50:24 PM »
Check if you've got things switched to headset.
txtriathlete
« Reply #2 on: June 02, 2020, 06:37:26 AM »
No not set to headset, it’s playing through the rear just fine. It won’t “fade” to the front. Both front speakers are plugged in tight.  I had the fairing off a while back, I’m wondering if I missed a connector somewhere. The two bullet connectors for each speaker are connected but maybe there is another plug in there I missed?
« Reply #3 on: June 04, 2020, 10:36:09 AM »
I always go to the fiche, look it over. The radio is simple. The speakers, those bullets, then the wire to a connector into the main, then the main to the radio.
I would unplug the radio. Plug back in.
Look over your setting. I believe I already sent you the owner manual radio settings? If you have to, take the inner fairing out, unplug the speaker, and plug it into the pod wire. Just to confirm that the speaker is work. It must be, since it's affecting both of them.
