August 26, 2025, 07:40:14 PM *
Author Topic: Mustang seat owners  (Read 679 times)
just8abug
« on: June 12, 2020, 11:04:42 AM »
I've got a 98 standard that I put a mustang seat on earlier this spring. Went to take it off today to get the wrench and adjust the shocks but the lock won't disengage. The key is working cause I can hear the mechanism under the seat moving but the seat won't come up using muscle or finesse.
Any tips or tricks?
« Reply #1 on: June 12, 2020, 11:13:31 AM »
Try pushing down on the seat as you turn the key.
just8abug
« Reply #2 on: June 12, 2020, 11:24:19 AM »
Ya, did that but to no avail. It's not tight under there as there is a little up and down play to the seat. The mechanism is working ( i can hear it moving) but it seems like it's not disengaging quite enough to release it.
« Reply #3 on: June 12, 2020, 11:43:21 AM »
Dont know had 3 mustang seats and never had an issue. Try pushing back on nose of seat or pushing forward on rear.
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #4 on: June 12, 2020, 12:04:46 PM »
The key cam is turning but is the cable off?
« Last Edit: June 12, 2020, 12:08:40 PM by _Sheffjs_ » Logged
just8abug
« Reply #5 on: June 12, 2020, 12:36:22 PM »
I guess it's possible...I'm hearing something moving under the seat when I operate the key. It's a head scratcher for sure!
bentwrench
Philadelphia,Pa.
« Reply #6 on: June 12, 2020, 02:26:41 PM »
Try using a long thin screwdriver, remove the left side cover and push the spring loaded catch till the the seat pops up.
Bigwolf
Cookeville, TN
« Reply #7 on: June 12, 2020, 05:33:56 PM »
I have 98 standard with mustang seat.  Never been a problem in the 10 years I have had it.  A few times I have had to hold the front of the seat down while turning key but that is all.
« Reply #8 on: June 12, 2020, 07:03:51 PM »
I think the seat latch sticking (or not working) is not specific to particular seats (including Mustang).
It happens.
Before I fiddled and lubed my seat latch, I had taken to getting on the bike seat before turning the key.
shadowsoftime
mannsville,ok
« Reply #9 on: June 12, 2020, 07:32:18 PM »
I had to bend my long skinny screwdriver and works well.
« Reply #10 on: June 12, 2020, 07:32:49 PM »
And be gentle removing the cover. Pull straight out from the back. There are 2 grommets. Then gently tilt the cover forward until it becomes obvious you can slide the tab free from its slot.
BE GENTLE.
just8abug
« Reply #11 on: June 13, 2020, 04:23:45 AM »
thanks  for all the help guys! I'll take the side cover off this morning and go that route. That's one I didn't think of.... cooldude
