April 30, 2026, 12:40:20 PM *
Author Topic: Oh, my! This is going to be a problem!  (Read 4574 times)
Bill Havins
A roadster!
Abilene, Texas
« on: June 12, 2020, 09:05:43 PM »
My Valkyrie has been sitting in the garage for a year-and-a-half.  Heavy sigh.  But I start it weekly, roll it around to prevent flat spots on the tires, and generally stare at it, wishing Judy and I were on our way out West.
I got a call from my earlier parttime job, asking if I would (please) come back to work.  The offer was too good to pass up.  Then I thought, "Heck, I'll ride the scooter to work!"  So I rolled it out in the driveway and gave it a well-deserved washing.  After I chamoised it off, I fired it up, and rode back into the garage.
The next morning I got up intending to change the oil, ride the Valkyrie to the Honda shop to get it inspected, renew my motorcycle insurance, and then ride to the DMV to renew my registration (yep, I had let everything lapse).
I rolled the bike backward out of the garage and halfway down the drive; I wanted to move to the other side of the garage where I had more open floor space.  Sitting on the sloping drive I hit the starter and the bike cranked but failed to start.  What!  I turned the key off, then, back on, listening for telltale sounds of what might be happening.  The dash came on per normal, I heard the faint sound of a relay, but the fuel pump didn't come on.  I tried again.  Same thing happened: no fuel pump.
"Crud," I said under my breath.  And then I pushed as hard as I could until I had the bike back in the garage.  This bike is not easy to push up a sloping drive when you weigh less than 140 lbs.
"Well," I thought.  "I have some troubleshooting to do."
Of course, the "obvious" issue to consider was the potential that water made it into one or more switches or connectors when I washed the bike.  Nope!  So I next checked fuses.  Nope!  Next I checked relays.  Nope!  So I peeled off all of the bike's plastic so I could raise the tank - I wanted to check the voltage on the plug that connects to the fuel pump.  And look what I found.  How that wire separated I will never understand.  But I knew it was going to be a problem.
I considered replacing the whole connector but it is unavailable.  Crud.  And the pins inside the connector are unavailable.  So, I decided to extract the pin with the separated wire (what a pain!), "uncrimp" it, and replace the wire with a pigtail I could then solder into the wiring harness.  It took almost all of today to get it done, but I got it done.
So, tomorrow I'm going to put the bike back together and change the oil.  Monday I'll get it inspected, renew my insurance, and renew my registration.  I'm glad the wire separated when the bike was within pushing distance of the garage.  Can you imagine trying to do this repair in a hotel parking lot when touring out West?  Not a pretty thought.
Stay safe out there.
« Last Edit: June 12, 2020, 09:09:59 PM by Bill Havins » Logged
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #1 on: June 13, 2020, 02:42:44 PM »
Some critter chew through it?
« Reply #2 on: June 13, 2020, 02:51:45 PM »
That's what it looks like to me.
It's hardly old age.
« Reply #3 on: June 13, 2020, 08:19:50 PM »
Adirondack Bill
Upstate New York Near Lake George
« Reply #4 on: June 16, 2020, 08:46:23 AM »
Darn critters. I had a critter build a little home in my empty battery box a couple of winters ago. I think it was a chipmunk,  there were quite a few nuts in there.
MnM Valk 97
Russellville, AR
« Reply #5 on: June 20, 2020, 08:31:33 AM »
I did some research a while back and ended up with a connector set from ebay that was the same family as OEM, which was not originally manufactured by Honda, but outsourced. You might try the "40Set Motorcycle Bike 2.8mm 2 3 4 6 Way Electrical Wire Connector Terminal Kit" from the seller lipenzhan-0. The specific set I bought is no longer listed, even by the seller I purchased from.
I have since moved and haven't unearthed that particular box yet, or I'd get you a picture of the connectors (which is what you're after by the sounds).
For the price, it might be worth getting a small set to see if it's what you're after. Hope that helps.
1997 GL1500CT
2015 GL1800C
