November 13, 2025, 04:54:29 AM *
Author Topic: 416 air shocks  (Read 1452 times)
scarylarry
wis rapids, wi
« on: June 15, 2020, 11:30:17 AM »
Bought my bike with air shocks..I'm pretty sure they are progressive 416's..no stickers on them..they have been leaking a little for awhile..now they ride super stiff like there is too much air pressure..but there isn't , so I'm thinking that's what they ride like when they are completely out of atf fluid..I called progressive and they told me they are out of any rebuild parts..So does anyone have a rebuild kit sitting around for sale or maybe even some used air shocks they'd like to part with? TIA
Jersey
VRCC #37540
Southern Maryland
« Reply #1 on: June 15, 2020, 11:40:33 AM »
You'll want to make sure which model you have. But the kits can be purchased on Amazon or Ebay fairly easily.  https://www.amazon.com/Progressive-Suspension-30-5041-Piece-Rebuild/dp/B0081XZDHS
Doing the job does require the tool https://www.progressivesuspension.com/product/1477/shock-tool-for-psi-shocks
I've repaired two sets and it's fairly straight forward.
Hope that helps.
Jersey
Jersey
« Reply #2 on: June 15, 2020, 11:49:27 AM »
Use Progressive Suspension Seals (Part #30-5041). If un-
available, Honda seals (Honda code 1062975 or 1534627)
may be substituted.
search for these progressive instructions   Inst # 3068, 3068-100, and 3068-101 Rev D,  7108-003 REV D WORK INSTR, 416 SHOCK ASSEMBLY.
this is the air hose kit that is recommended by progressive.
https://www.ebay.com/itm/Gabriel-141099-Air-Shocks-Hose-Kit-with-Tubing-and-O-rings-QUANTITY-OF-2/152298239780
scarylarry
wis rapids, wi
« Reply #3 on: June 15, 2020, 10:47:20 PM »
Jersey, when you rebuilt your shocks did they get to the point that they had no travel at all left in them..kinda thinking there might be more going on here
