November 13, 2025, 03:04:54 AM *
Author Topic: shocks again..sorry  (Read 1196 times)
scarylarry
wis rapids, wi
« on: June 17, 2020, 11:40:26 PM »
I posted previously about my air shocks leaking oil and got some good info from a cpl members about part #s and instructions.  My concern is there might be something else wrong besides out of oil.  I would think the shocks would be real spongy and bottom out easily.  They act the opposite, they are super stiff with no travel, even without any air in them.  Again, any help is greatly appreciated.
« Reply #1 on: June 18, 2020, 02:44:50 AM »
If they are like other progressive shocks, the spring rates should be (stamped or embossed) in small numbers on the coil spring.  There should be two numbers.  Those numbers can be (or used to be) researched on Progressive's website, or call them and ask for tech assistance and ask.  Whether air or oil shocks, the springs will continue to function even if the air or oil are leaky or defective.  It sounds like your springs are on the heavy duty side.  I do not know if Progressive will rebuild 416s, but even if they don't they may agree to change the springs in them (to lower rates).
http://www.promecha.com.au/springs_basics.htm
https://www.progressivesuspension.com/c/tech-info-springs
