November 13, 2025, 03:06:12 AM *
Author Topic: Before I screw something up  (Read 1515 times)
AwesomeDad
TN
« on: June 22, 2020, 02:51:25 PM »
Going to pick up my Valk on Wednesday. It’s low miles but has been ridden. I’m taking a 5 gallon can of ethanol free gas with me, do I just need to add carb cleaner to the tank or should I go with sea foam or B12 for the first full tank?
JJ
« Reply #1 on: June 22, 2020, 03:36:01 PM »
Is it a running machine? If running anyone will be ok. If not you gonna need more than fuel additives.
AwesomeDad
TN
« Reply #2 on: June 22, 2020, 03:43:20 PM »
He says runs fine, I’m just concerned that he hasn’t ridden it much...
JJ
« Reply #3 on: June 22, 2020, 04:21:43 PM »
I never put anything but gas in mine...
-Mike "ride it often enough to keep it from gumming up  cooldude "
« Reply #4 on: June 22, 2020, 04:48:54 PM »
I put in some B-12 periodically to keep the fuel system cleaned up. I have had B-12 improve the running of bikes that have sat too long.  And since Murphy's came into the neighborhood I run only pure gas locally.  But on the road, usually have to use corn gas.
Pluggy
Vass, NC
« Reply #5 on: June 22, 2020, 04:52:16 PM »
You have to follow the instructions using Sea Foam and similar products.  Some guys will tell you "Go ahead and dump in a whole can".  That's like swallowing a full bottle of aspirin if you have a headache.  Although those additives are flammable, they are not motor fuel.  Too much in the gas may create a mixture that doesn't burn very well.
My 4 cylinder Honda would not idle correctly with a heavy dose of Sea Foam in the tank.  One used up and replaced with straight gasoline, the problem was over.
Calboy
« Reply #6 on: June 22, 2020, 05:19:11 PM »
I heard that the month of October of 2030 is supposed to be cooler than normal and I don't know how to dress.
That's basically what you're saying.
Dude, go there, start up the bike, see how it idles, ride it for a few miles, and then decide.
Even if you add I don't know what, or I don't know how much of this and that to the gas in the tank you're not going to notice a difference right away.
Ride it home, if you think is worth it, and let the  fun begin!
AwesomeDad
TN
« Reply #7 on: June 22, 2020, 05:25:07 PM »
I understand that, I just didn’t want to over do it. I’m betting anyone selling a bike is gonna say oh run runs perfect... I’ve talked to a couple sellers that were so proud they drained the carbs and tank before storing it for 3 years...
JJ
CoreyP
Bluffton, SC
« Reply #8 on: June 22, 2020, 07:47:55 PM »
Fire it up and see what it sounds like. It might be fine.
h13man
Indiana NW Central Flatlands
« Reply #9 on: June 23, 2020, 07:28:55 AM »
I use a 1/2 can per 5 gal. (80:1 ratio) Cleaned my carbs within 2 mi. after fill. Like MarcT, Berry B12 about every 2,000 mi./2 times a season.
AwesomeDad
TN
« Reply #10 on: June 24, 2020, 04:47:56 PM »
Runs fine, ride it home...
JJ
