March 13, 2026, 08:21:12 PM *
Author Topic: playing with car tires tooo!  (Read 2190 times)
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« on: December 17, 2009, 06:59:36 PM »
Hankook, 42 psi, n rub. had to deflate to 25 psi to get past differential then aired it back up.
i just dont like the weights, tape ons. thank goodness for Gorilla glue.  Cool
VRCC#31391
VRCCDS0239
« Reply #1 on: December 18, 2009, 04:39:37 AM »
Thats a good looking tire and I love the exhaust however I don't think those turned down like that would make it out of the valley road I live on much less hittin' the twisties like The Dragon , The Devils Triangle,The Snake etc. I had a buddy with 38 inch straight cut and he destoryed them in the curves ( mostly down-hill tight curves he would drag with the pipes  Undecided  ) . I've run the Cooper Zeon 2XS ( rated 280 ) on my bikes for years but thought I'd try something new and went with the Fuzion ZRi ( rated 320 ) on my last one and when its rear tire time for the others I'll be mounting a Fuzion ZRi on them as well.
What size is the Hankook ?
What is it rated ?
Is it a directional ?
Picture below is the Fuzion ZRi I'm really diggin' this tire and love the way it hangs in the twisties.
V98
« Reply #2 on: December 18, 2009, 05:07:01 AM »
You can buy the original clip on weights at HDL  cooldude.
roboto65
Conroe,TX
« Reply #3 on: December 18, 2009, 05:40:02 AM »
You could take the weights OFF if you use Dyna Beads !!!
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
« Reply #4 on: December 18, 2009, 09:38:14 AM »
What is it rated ?
Thats a K-106 Hankook. Thats what I run and crazyhorse does to I beleive. Its kinda round so I rarely know its a car tire. Directional? It only mounts one way so I guess it is.  Undecided
« Reply #5 on: December 18, 2009, 09:47:43 AM »
I looked it up and it does'nt say its a directional pattern so I'm guessing its not  ???
The Hankook K106 is a new high performance radial designed for serious driving excitement. The radical v-shaped tread pattern efficiently disperses water without compromising speed or handling. * High Performance * H, V Rated * UTQG: 340/A/A * 35/40/45/50/55 Series * 16, 17, 18 Inch * VSB: Vertical Serrated Band
« Reply #6 on: December 18, 2009, 01:09:09 PM »
42 psi might wear the center out . I did that to the first Cooper I put on.
Jack
Benton, Arkansas
« Reply #7 on: December 18, 2009, 03:11:46 PM »
I've had a Hankook like that for 3 years now.  Still looks and handles great although I never balanced it or any other tire on my bike.  I run 40 psi.
alph
Eau Claire, WI.
« Reply #8 on: December 18, 2009, 03:36:14 PM »
I put dyna beads in my tires last spring, pulled off the lead weights, and noticed a difference immediately!  I experienced an incredibly smooth vibration free ride!
Although, from what I remember the manufacture doesn't recommend dyna beads for cars, but does for car tires on motor cycles?!?!  Or am I reading that incorrectly?
The only thing I could possibly dislike about them is that you can’t plug your tire if you get a nail in it, you have to get a patch put in on the inside.
bigdog99
Kouts Indiana
« Reply #9 on: December 18, 2009, 05:37:15 PM »
it is the k-106. right now when i took it off it looks to have really even wear. the reason i run 42 psi is i ride double 95% of the time. anything lower than that i could feel the side wall buckle a little when it hit a bump on a curve. threw a swerve if you will.
as far as the cornering for the pipes, ever been to Harrison Arkansas? 110 miles, 662 curves. found it last year and scraped footpegs several times but never the turn downs. the picture makes them look wider than they really are. they fit well under the bags. they only time i scraped them was when i went around a corner and found out i went through a gallon of motor oil left on the road by a CAR DRIVER. the sun was behind me and camo'd it. it hit the bag rails about the same time as the pipes.   p.s. if you talk to my wif about them make sure you say "THROATY", if they were loud i couldn't have cut my pigs.!!!! Evil
VRCC#31391
VRCCDS0239
« Reply #10 on: December 18, 2009, 05:46:18 PM »
42 psi huh? I'm at 38 and get that same feeling in curves, esp 2-up loaded. I 'accidently' put in 50-52 psi in SD. Talk about the best handeling and ride ever! Did this for 300 miles. It flew down the road. I really like this tire so far. Only took a few miles to get use to it.
What corner of the State are you?
bigdog99
Kouts Indiana
« Reply #11 on: December 18, 2009, 05:52:03 PM »
north west  was actually going to go to your neck of the woods thais past year coming back from AR. Wifes back acted up and we cut it short.
VRCC#31391
VRCCDS0239
« Reply #12 on: December 18, 2009, 06:15:14 PM »
Well come on down. Not much here but we deal with it! Lotta Valkers in this area. I only get your way twice a year, and we are always hellbent for leather.
bigdog99
Kouts Indiana
« Reply #13 on: December 18, 2009, 06:16:28 PM »
nest time comin that way i give you heads up!  cooldude
VRCC#31391
VRCCDS0239
