August 26, 2025, 04:37:46 PM *
Author Topic: Got her home  (Read 877 times)
AwesomeDad
TN
« on: June 24, 2020, 03:17:52 PM »
Long day but picked up my new to me Valk. Won’t get into the details  but it’s a low mile 2001. And I’m dropping it off Tuesday for a general service and timing belt.
JJ
« Last Edit: June 24, 2020, 03:23:24 PM by AwesomeDad » Logged
« Reply #1 on: June 24, 2020, 03:44:06 PM »
Didn't happen without pictures.. See it now.  Purty bike.
« Last Edit: June 25, 2020, 06:20:55 AM by Valkorado » Logged
AwesomeDad
TN
« Reply #2 on: June 24, 2020, 03:44:58 PM »
Is the pic not showing? I’m seeing it...
JJ
klb
Hickory nc
« Reply #3 on: June 24, 2020, 03:45:59 PM »
Nice. Like them Blue and White ones. I see the picture also.
AwesomeDad
TN
« Reply #4 on: June 24, 2020, 03:54:15 PM »
Thank you I’m kinda a fan of blue...
JJ
« Reply #5 on: June 24, 2020, 04:02:24 PM »
Do the service yourself not likely a mechanic at a bike shop has ever worked on one either.  And you will save a ton of money plus you will know it was done correctly.
Oh and congrats.
AwesomeDad
TN
« Reply #6 on: June 24, 2020, 04:14:44 PM »
Oh and congrats.
I have a local guy specializing in GL bikes. And yes I was shocked that the local Honda shop can’t work on anything prior to 2005. I have no issues doing it myself but the timing belt I want done right the first time. And I also want the bike road worthy ASAP. I already did most of the fluids myself when I got home. All they will be doing is the timing belt, coolant flush, final drive and brake calipers.
I’d rather they get it in and started rather than me not getting to it for a couple weeks due to work...
JJ
« Reply #7 on: June 24, 2020, 04:24:13 PM »
timing belt, unless mistaken, is 100K or so and you said low mileage so does it need done for what reason?
coolant flush is easy peesy if you can change oil you can do the antifreeze is one small bolt in front.
« Reply #8 on: June 24, 2020, 06:29:11 PM »
You do know in case you decide to do it yourself later it’s two belts not one like car engines
Disco
Republic of Texas
« Reply #9 on: June 24, 2020, 07:25:36 PM »
New ones are cheap and his are probably 20 years old.   coolsmiley
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
AwesomeDad
TN
« Reply #10 on: June 25, 2020, 05:11:53 AM »
Exactly, and yes I ordered 2 belts. And he previous owner did nothing to it because he went by mileage. He had the bike 7 years never changed the oil....
JJ
« Reply #11 on: June 25, 2020, 06:26:11 AM »
JJ
I'd run it about 100 miles on the new oil and then change the oil and filter again.
AwesomeDad
TN
« Reply #12 on: June 25, 2020, 07:54:08 AM »
JJ
Probably gonna do about 3 changes the first 1000 miles...
JJ
Thunderbolt
Worthington Springs FL.
« Reply #13 on: June 25, 2020, 05:03:53 PM »
Looking good.  I put a set of those pipes on my 97 Tourer.  Gave me a headache so they didn't last long.  Remind your mechanic that there are three O-rings to change and a sequence to torquing everything.
« Reply #14 on: June 25, 2020, 06:48:34 PM »
Yeah he probably dont know that as he is a wing mechanic.
