March 26, 2026, 04:19:31 AM *
Author Topic: Need my service in Arkansas or north of Louisiana?  (Read 1155 times)
BigBF
Text message at 602-332-4872
Phx AZ
« on: June 24, 2020, 08:58:22 PM »
Ok I’m done with two Trike both overhaul carb and done with sidecar install triple tree and rebuilt both forks in Greenville Texas.
I need to be close to Tulsa for my doctors appointment on July 5 and 6 so I don’t see anyone sign up in north Louisiana or in Arkansas there’s one in far north Arkansas I’ll contact them if they need my service since don’t see anyone in north of Louisiana or Arkansas?
BigBF
Phx AZ
« Reply #1 on: June 25, 2020, 01:29:03 PM »
Ahead back to Tulsa and wait for my Doctor appointment since none in Louisiana and Arkansas to work on Valkyries
I didn’t want go far off by return and go back on way to InZane. I’ll go to InZane after my eye dr.
« Reply #2 on: June 25, 2020, 01:59:51 PM »
Hey Bill, after North Carolina Inzane, would you be coming up onto Virginia after that?
« Reply #3 on: June 25, 2020, 02:36:12 PM »
Bill, were you planning to register for InZane?
BigBF
Phx AZ
« Reply #4 on: June 25, 2020, 02:56:57 PM »
Yes I will be but later like in Fall  I’ll need go to ND then head for NH then south to FL then to AZ.
BigBF
Phx AZ
« Reply #5 on: June 25, 2020, 02:58:30 PM »
Yes do I need to do that? I won’t need hotel room thought.
Can pay at InZane so count me in ok?
BigBF
Phx AZ
« Reply #6 on: June 25, 2020, 02:58:43 PM »
Update I’ll be going far northwest of Arkansas but two mile north of MO state line at walmart to work on #29 Valkyrie interstate.
« Reply #7 on: June 26, 2020, 07:58:15 AM »
Yes, you do.  The sooner, the better so we can plan and set aside a work area for you.  If you wait until InZane to register the banquet dinner will not be included in your registration.
BigBF
Phx AZ
« Reply #8 on: June 26, 2020, 08:34:50 AM »
Oh right. Ok I’ll get on it
« Reply #9 on: June 27, 2020, 04:36:58 AM »
keep me in the loop Bill for my 01   Maybe Gman will have some work needed too by then
Will need a rear tire by then  should make it to inzane and back   angel   Will either use the austone I have in the basement or get another 200 series bridgestone exedra
   If you do not have tools to mount will have to go to stealer   Cry
but will have you do the spline maintenance as do not trust them
Also front is really stiff going over bumps  maybe change weight of oil in forks?
Take it for a ride and let me know  Blue Pig ice cream on me of course
« Last Edit: June 27, 2020, 04:39:21 AM by Oss » Logged
« Reply #10 on: June 27, 2020, 07:02:23 AM »
Bill,
It's good to know you're out there still roaming around and available for assistance! You really bailed us out of a tight-spot a couple of years ago in Michigan, and that made all the difference for us! Our girl and I don't need anything at the moment, but I will try to keep tabs on you... just in case!!! In the meantime, best of luck to you, and I wish you much success in your 'niche market specialty'...
0leman
Klamath Falls, Or
« Reply #11 on: June 27, 2020, 07:28:53 AM »
Glad to hear your still moving around.
Good luck on your doc appointment.
BigBF
Phx AZ
« Reply #12 on: June 29, 2020, 08:58:44 PM »
I can take it off and u bring it to some place to do tire change and balance
It will be somewhere probably at John Farcher if he ok for anyone bring over. He’s north from you in Saugerties. My trailer are bigger now.
BigBF
Phx AZ
« Reply #13 on: June 29, 2020, 09:00:24 PM »
Bill,
Hi DDT
No problem and thanks. Hope we will meet at InZane or somewhere.
BigBF
Phx AZ
« Reply #14 on: June 29, 2020, 09:00:55 PM »
« Reply #15 on: June 30, 2020, 12:39:47 PM »
Oss,
Put on the Austone.  Works great with the BigFoot I have for you!
« Reply #16 on: June 30, 2020, 02:19:31 PM »
Bill - you going to be anywhere close to KC ? My '98 standard could probably use rearend  work and a good going over in general (maybe tires too).
