November 13, 2025, 03:05:57 AM *
Author Topic: Task List for Newer Valkyrie Owners  (Read 1290 times)
jnicks01
Clinton, IN
« on: June 29, 2020, 05:29:00 AM »
Hey guys,
I know that there have been many posts with questions on what to do for maintenance.  Mainly from newer owners.  I am one.  I am going on season 1 with this beast.
I've done a ton of research and feel I have a decent list of things that should be done, desired to do, and things I still have to do.
I just wanted to share this and hope it lends a helping hand for some of us rookies.
I'm sure there will be opinions of why I should/shouldn't do this or that, but overall i think it is pretty comprehensive.
https://docs.google.com/spreadsheets/d/1--1Om0JZQCnmOauWJk8buXazvL9CY9SX56OMCE9vNXU/edit?usp=sharing
I want to scoop out your brains and eat your knowledge.
« Reply #1 on: June 29, 2020, 08:39:58 AM »
Yup, that's pretty doggone comprehensive alright.
Desmog?  Electric fuel shutoff?  Stainless lines?  DARKSIDE?
Factor
Clayton, NC
« Reply #2 on: June 29, 2020, 11:27:48 AM »
Pretty thorough.
I'd add "clean start switch contacts" Mine were corroded and began to melt. This will stop the train entirely. I only just managed to save them. Otherwise, you're looking at a new start switch assembly.
Also, assess your fork springs. Sagging fork springs make for bad handling. Especially noticeable at 80 mph when you're passing a truck in a turn and you hit a bumpy expansion joint.  Shocked
Steve
VRCC# 38798
'75 Hoda GL1000 Project
'83 GL1100 MonkeyWing
'70 Suzuki T500 Titan
'99 Valkyrie Tourer
'64 MGB
'89 Isuzu Trooper 3.4L
IBA #58082
All my stuff is old. It makes me feel young.
« Reply #3 on: June 29, 2020, 11:52:37 AM »
If it’s running and riding well, then there’s no hurry on major maintenance. One issue that’s usually ignored is the rear drive. Change the fluid in it and use a good synthetic gear oil. Check the drive train. Engine off, in gear and roll it back and forth. Do you hear/feel any issues? If not, then R&R the rear wheel next fall after the riding season. Check wheel splines and drive shaft.
Jersey
VRCC #37540
Southern Maryland
« Reply #4 on: June 29, 2020, 02:13:36 PM »
Don't forget to add the premier mods:
1. SignalBoss for autocancelling turn signals and hazard/escort flashing
2. Jersey Bracket for fixing the sloppy shifter design
3. ECT Mod for increasing the ignition advance and giving a bit more getup-n-go!
JerseyMCProducts.com
Jersey
