November 13, 2025, 02:54:52 AM *
Author Topic: Trick to reinstall the radiator?  (Read 1072 times)
allanbegg
Marietta, PA
« on: June 29, 2020, 11:33:15 AM »
All,
I'm looking for detailed instructions on how to reinstall the radiator.
I removed mine to access the thermostat housing.
Now, I'm struggling to get the radiator back onto the two guide bolts at the bottom. The upper hose neck on the top right of the radiator hits the frame and prevents the radiator from moving over to the left enough to get the guide bushings to slip over the guide bolts. I seem to need about 1/2" of additional room.
It was a struggle to take the radiator off and I don't want to use the same "just force it" method to put it back on, if there is something simple that I am missing.
Thanks, Allan
VRCC # 36795
« Reply #1 on: June 29, 2020, 01:54:22 PM »
Radiator on first then attach hoses
allanbegg
Marietta, PA
« Reply #2 on: June 29, 2020, 06:24:44 PM »
No hoses attached to the radiator yet.
It's the upper hose neck that interferes with the frame and prevents the radiator from sliding over enough to align with the guide bolts.
« Last Edit: June 29, 2020, 06:27:28 PM by allanbegg » Logged
VRCC # 36795
shadowsoftime
mannsville,ok
« Reply #3 on: June 30, 2020, 10:03:09 AM »
i took mine off awhile back, don't remember a problem reinstalling.
