June 22, 2025, 03:33:13 PM *
Author Topic: Front U Joint  (Read 1192 times)
valktrike
« on: July 01, 2020, 08:10:11 AM »
Does anyone know if the Valkyrie Motor Trike conversion uses the oem Honda front u joint?
« Reply #1 on: July 01, 2020, 09:22:03 AM »
Sorry don't know, could you not contact the manufacture?
Whether or not it can be used, it would be up to the person who installed it on your bike if they used it or something else.
3W-lonerider
Shippensburg Pa
« Reply #2 on: July 01, 2020, 04:43:12 PM »
yes they do. but if your drive shaft has been updated to the newer shaft then no. old drive shaft is black. new drive shaft is green. iv'e run both drive shafts and in my opinion the newer drive shaft from motortrike is well worth the money. old drive shaft the yokes on the front universal would get worn and create an eliptical motion on the shaft. newer shaft removes that issue.
valktrike
« Reply #3 on: July 13, 2020, 12:15:38 PM »
Thank you so much! Mine must be the original because it's black. I'll check into an OEM front u joint.
3W-lonerider
Shippensburg Pa
« Reply #4 on: July 13, 2020, 01:38:02 PM »
when you install the new joint. make sure you time it properly or you will get a vibration you won't soon forget.
take a  very close look how the shaft is lined up now and repeat it when installing the new one.
