June 22, 2025, 03:44:21 PM
Tail light fender removal
Topic: Tail light fender removal (Read 1088 times)
AwesomeDad
TN
July 11, 2020, 10:17:51 AM »
Yes I’ve searched and read. Most topics covered the super Valk conversion. All I want to know is to change the rear fender do you have to cut the wires for the tail light assembly or can the harness be fed thru the opening?
JJ
indybobm
Franklin, Indiana VRCC # 5258
Re: Tail light fender removal
July 11, 2020, 10:26:35 AM »
Wires disconnect at the taillight assembly and the stop light, bullet connections. there is a square connector at the junction of the two rear fender sections.
So many roads, so little time
VRCC # 5258
AwesomeDad
TN
July 11, 2020, 11:19:04 AM »
Quote from: indybobm on July 11, 2020, 10:26:35 AM
So worse case I’d just have to replace the bullet connectors...
July 11, 2020, 02:39:19 PM »
Honda bullet connectors are 3.5 mm, not the 4 mm of a standard auto wiring.
http://www.cycleterminal.com/solenoid-connectors.html
http://www.vintageconnections.com/
You should be able to find them on either one of the above sites.
AwesomeDad
TN
July 11, 2020, 03:32:20 PM »
Quote from: gordonv on July 11, 2020, 02:39:19 PM
Thanks a bunch...
July 12, 2020, 04:20:01 PM »
Quote from: AwesomeDad on July 11, 2020, 11:19:04 AM
No. You should be able to feed the wires out of the fender after disconnecting them.
AwesomeDad
TN
Reply #6 on:
July 13, 2020, 08:16:45 AM »
Quote from: Hook#3287 on July 12, 2020, 04:20:01 PM
I’ll give it a try
Madmike
Campbell River BC, Canada
Reply #7 on:
July 13, 2020, 08:29:32 AM »
Quote from: AwesomeDad on July 11, 2020, 03:32:20 PM
Thanks a bunch...
amazon has them as well if you have Prime
=> InZane XXV
