June 22, 2025, 03:52:39 PM
Weak cylinder question
Topic: Weak cylinder question (Read 1082 times)
yrunvs
Prior Lake, Minnesota
July 12, 2020, 07:04:39 PM »
I have been chasing down and fixing various problems with my new to me Valk. One of the "situations" is a popping at idle and slow speeds while applying small throttle. Previously, I noticed my #3 header did not heat up as much or as fast at idle as all of the other exhaust headers. While fiddling with the pilot screws I noticed that when I pulled the spark plug cap off #3 and applied throttle the popping was not present. So to recap....at idle with a small throttle their is popping and missing but when #3 plug cap is pulled off the popping at small throttle stops?? All suggestions appreciated.
I'm no gynecologist but hey I'll take a look!
WintrSol
Florissant, MO
Re: Weak cylinder question
July 12, 2020, 08:18:13 PM »
plugged pilot jet, leaking vacuum hose either the one on the intake or 'coast' valve, leaking down tube possibly at the O-ring seal
wirral_biker
Wirral, ENGLAND
July 13, 2020, 05:18:25 AM »
As above, blocked slow running pilot jet. Doesn't pop when not in use !!
I will never learn, on my 4th Valkyrie now !
yrunvs
July 13, 2020, 08:01:11 PM »
Thanks for the responses. #3 carb needs a cleaning.
9Ball
July 14, 2020, 04:48:00 AM »
If number 3 needs cleaning, then you might want to invest the time and expense to go through all six carbs.
I hate doing the same job twice by taking short cuts. Others will probably disagree but that’s my opinion and practice.
Good luck...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
yrunvs
July 14, 2020, 06:21:58 AM »
I hear ya. I'm going to pull the entire carb bank at the end of the riding season and "reclean" and install new orings and may even go with 38 slow jets. Going to check those pesky air cut off thingies too.
But for now I was thinking of just removing (or at least trying to) #3 bowl to get at the jets and maybe shoot carb cleaner in the passages.
=> InZane XXV
