December 30, 2025, 06:21:10 PM *
Author Topic: Velocity stack clearance  (Read 1286 times)
AwesomeDad
TN
« on: July 16, 2020, 10:10:28 AM »
I’d read a post about interstate tanks not clearing if velocity stacks are installed, what was the fix?
JJ
« Reply #1 on: July 16, 2020, 10:46:41 AM »
Raising the tank with thick washers under the mounting points
AwesomeDad
TN
« Reply #2 on: July 16, 2020, 10:47:14 AM »
Thanks will try it...
« Reply #3 on: July 16, 2020, 11:39:46 AM »
also need to add to the rubber pads on the frame.
AwesomeDad
TN
« Reply #4 on: July 17, 2020, 09:39:46 AM »
Do you have a link?
JJ
« Reply #5 on: July 17, 2020, 12:24:57 PM »
Do you have a link?
JJ
Not really. But this is one way of doing it. I did it differently. I added a split heater hose under the OEM tank rubber bumpers.
http://www.valkyrieriders.com/shoptalk/vstackspacermod.pdf
AwesomeDad
TN
« Reply #6 on: July 17, 2020, 12:38:25 PM »
Do you have a link?
JJ
Perfect thanks!
