March 25, 2026, 11:31:02 PM *
Author Topic: Needing some info  (Read 765 times)
shadowsoftime
mannsville,ok
« on: July 27, 2020, 08:38:25 PM »
Will hydraulic fluid damage, stain a convertible top and how to clean it off.
Cylinder leaked and shot a lot of fluid on my black top.
« Reply #1 on: July 28, 2020, 03:34:56 AM »
A valkyrie has a convertible top? angel
Good luck sorry I cant help.
da prez
Wilmot Wi
« Reply #2 on: July 28, 2020, 04:31:15 AM »
 Dawn dish soap. 50/50 mix with water. apply and scrub.
                                      da prez
Jersey mike
Brick,NJ
« Reply #3 on: July 28, 2020, 04:50:26 AM »
                                      da prez
This sounds like a good response, Dawn dish soap is some great stuff. The only thing I would add is lots of rinsing and keep it out of the sun if possible. After washing if you let it dry in the shade or garage.
da prez
Wilmot Wi
« Reply #4 on: July 28, 2020, 03:42:41 PM »
DITTO  Jersey.
                    da prez
« Reply #5 on: July 28, 2020, 06:03:34 PM »
What is the car, they have different fluids. But I would try some Shout as a general rule.
If there is not to much you could just wipe it off.
The Mercedes and BMW stuff is a bear to take off but usually does not stain and can be wiped off the cloth tops, at least enough to let the rain do the rest. Dont underestimate a good car wash soap either they do tend to take out oil a bit better than most and usually will not hurt the material.
« Last Edit: July 28, 2020, 06:07:36 PM by Robert » Logged
« Reply #6 on: July 29, 2020, 08:21:51 PM »
Check with a Marina, they have a lot of good experience with canvas.
And when you figure it out, post it here, I might need it one day on my own convertible.
shadowsoftime
mannsville,ok
« Reply #7 on: July 30, 2020, 06:59:27 AM »
It is a Mercedes.
shadowsoftime
mannsville,ok
« Reply #8 on: July 30, 2020, 07:06:09 AM »
I used Dawn and the stain is still there. Next will try upholstery cleaner and shop vac.
Went on youtube to see how to replace cylinders and looks to be a real PITA.
