December 30, 2025, 04:36:00 PM *
Author Topic: Ron Ayers website  (Read 1230 times)
yrunvs
Prior Lake, Minnesota
« on: July 28, 2020, 02:08:15 PM »
Nothing comes easy for me Sad
https://www.ronayers.com/oemparts/c/honda_motorcycle_2000/parts
On the website their are 10 GL1500 options to chose from depending on the Valk you have. I have a 2000 Valk Standard model so which of the 10 is right for mine. The reason I ask is I would have thought GL1500CA or Gl1500AA but apparently it matters because the wheel damper part number for each is different.
https://www.ronayers.com/oemparts/a/hon/506cb6b9f870023420a4194c/rear-wheel
https://www.ronayers.com/oemparts/a/hon/506c1e0af870023420a2f26d/rear-wheel
« Last Edit: July 28, 2020, 02:10:17 PM by yrunvs » Logged
I'm no gynecologist but hey I'll take a look!
« Reply #1 on: July 28, 2020, 02:19:29 PM »
Wheel dampers changed and the ones for the IS are more durable I think (if I remember  correctly)
They should all be the same size.
« Reply #2 on: July 28, 2020, 02:36:14 PM »
GL1500C is the Valkyrie Standard.
I believe the Dampers you want are 06410-MBH-000.
yrunvs
« Reply #3 on: July 28, 2020, 02:39:51 PM »
Yes Sir you are right I just cross referenced the number to another site. So the correct one for the Valk Standard on Ron Ayer site is designated GL1500C A.
« Reply #4 on: July 28, 2020, 02:58:01 PM »
There (originally) used to be only 2-peice dampers for std/tourers where the rubbers and metal inserts were both required, and you poked the inserts in yourself.
The interstate dampers later came as a one-piece design, with the inserts already inserted onto the rubbers, and they were cheaper, and better designed.  But both versions would work in any model or model year Valk.  I thought Honda carried both for a while, but later discontinued the 2-piece (because making both was stupid in the supply chain, and anyone who knew the difference would always get the cheaper and better one-piece versions).
This is why when I earlier posted the link to the damper part numbers, I used the '99 interstate, because those are the ones you want.  I used the ProCaliber website parts fishe, but you may find them cheaper.
I will post a part as the correct one to an inquiry on here, but I'm not going to do the shopping around for best price.
« Last Edit: July 28, 2020, 03:00:50 PM by Jess from VA » Logged
Madmike
Campbell River BC, Canada
« Reply #5 on: July 28, 2020, 06:32:02 PM »
Thanks Jess, I was going through part #'s and trying to remember where this was mentioned, the full explanation is what I needed.   cooldude
« Last Edit: July 28, 2020, 06:33:35 PM by Madmike » Logged
« Reply #6 on: July 28, 2020, 06:35:00 PM »
Not only will the dampener fit in any GL1500 Valkyrie, they will also fit in any 90'-00' Goldwing GL1500 too (5 spoke hub).
I don't recall who makes them now, but I bought one of the last batch from a seller in WA who used to make a better replacement one, Gary's dampeners, pasted back in what, 2013?
