December 30, 2025, 04:35:08 PM *
Author Topic: 2001 Interstate Trunk Latch  (Read 1513 times)
mhallock
Sussex County, NJ
« on: July 29, 2020, 12:05:41 PM »
I locked my trunk for the first time in a long time today. Now the latch release on bottom doesn't work. Only the key will open the trunk. What is the simplest way to access that latch area?? I don't want to remove too much if I don't have to....Probably just a cable adjustment....Thanks.
Mark
« Last Edit: July 29, 2020, 12:08:37 PM by mhallock » Logged
3W-lonerider
Shippensburg Pa
« Reply #1 on: July 29, 2020, 12:26:48 PM »
 You have to unlock it for that latch to the work.
« Reply #2 on: July 29, 2020, 12:32:27 PM »
The same thing happened to me.
Only took a few days to figure it out (big forehead smack).
It's a truck, but different from every car trunk you ever had.
mhallock
Sussex County, NJ
« Reply #3 on: July 29, 2020, 12:32:42 PM »
Yes, I can unlock it with the key only...
mhallock
Sussex County, NJ
« Reply #4 on: July 29, 2020, 12:35:03 PM »
Jess....exactly what did you figure out?? Do ALL the screws and bolts need to be removed to get the liner out??
« Last Edit: July 29, 2020, 12:37:29 PM by mhallock » Logged
3W-lonerider
Shippensburg Pa
« Reply #5 on: July 29, 2020, 12:51:34 PM »
Is your slot facing sideways or straight up and down. Been awhile since I’ve had an interstate but I’m thinking straight up and down is locked. Then you would turn the key counter clockwise to use the key to unlock it. Turn the key clockwise as far as it goes and it should be unlocked so the lever will work.
SCain
Rio Rancho, NM
« Reply #6 on: July 29, 2020, 12:59:41 PM »
With the slot vertical, turn the key counter clockwise (about 10 oclock) and the lock will pop open, now turn the key clock wise to the 3 oclock (Horizontal) position and the latch lever under the trunk will work again. It does not work if the key is in the verical (locked) position.
Steve
mhallock
Sussex County, NJ
« Reply #7 on: July 29, 2020, 01:16:01 PM »
Thank you SCain!! We have a winner!!
Mark
« Reply #8 on: July 29, 2020, 02:40:28 PM »
Sorry I wasn't more clear.  When you lock it, it stays locked (once closed).  And you have to return the key back to the unlocked position for the underneath lever to work again.  Not intuitive at all.
mhallock
Sussex County, NJ
« Reply #9 on: July 29, 2020, 04:08:57 PM »
I guess I've done that for the last 19 years.......until today....oh well....
Mark
Ramie
2001 I/S St. Michael MN
« Reply #10 on: July 29, 2020, 07:23:17 PM »
I had mine torn apart figuring I'd find a broken cable, surprise!!
« Reply #11 on: July 29, 2020, 07:27:12 PM »
It's always easier reading the owners manual on things like this. The trunk, saddle bags, side covers, radio, seat release, etc....  Shocked
