December 30, 2025, 04:36:28 PM *
Author Topic: Shocks Question  (Read 1266 times)
Whooray
Idaho State Rep
Kuna, Idaho
« on: August 02, 2020, 07:00:40 AM »
I have 2 sets of shocks both OEM.
One set is MZO 003 and the other is MZO A41 is there a difference in the two?
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
h13man
Indiana NW Central Flatlands
« Reply #1 on: August 02, 2020, 07:44:18 AM »
52400-MZ0-003 was used on 97' and 98'. 52400-MZ0-A41 was used from 99' thru 03'. Both numbers fit the 1500C standard and 1500CT Tourer as the hardware to bolt them on are the same. The Interstate shows a completely different #.
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #2 on: August 02, 2020, 08:18:15 AM »
Thank you for the info..... Now I know... Much appreciated
« Reply #3 on: August 02, 2020, 12:33:03 PM »
But all 3 versions are interchangeable, but not always recommended to put a C/CT shock on an IS. The IS uses a heavier spring, and is recommended for the other models.
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #4 on: August 02, 2020, 02:35:04 PM »
 cooldude cooldude
-mike-
Germany
« Reply #5 on: August 02, 2020, 09:34:13 PM »
I replaced the stock shocks on my Standard with IS ones recently. (I'm a heavy guy.... )
I do like it a LOT! As Gordon said - the IS shocks are meant for higher weight..
-mike-
« Last Edit: August 02, 2020, 09:35:56 PM by -mike- » Logged
« Reply #6 on: August 03, 2020, 09:53:04 PM »
'99 thru '03 were re-valved like the I/S units for a smoother ride. The spring rates stayed the same as the  '97-'98 shocks, as far as I could find out.
