December 30, 2025, 04:35:48 PM *
Author Topic: Yet another problem  (Read 1385 times)
shadowmagic
« on: August 11, 2020, 01:36:28 PM »
So now I'm having issues with the bike starting sometimes. Sometimes it will just give a clicking sound after a couple of pushes of the button then it will start. I'm assuming something is about to go out. Sound like it may be the relay is that right? I dont know how old this battery is either so I may just buy a new one. Other than the battery and the starter button housing, anything else it could be?
mello dude
Dayton Ohio
« Reply #1 on: August 11, 2020, 01:52:01 PM »
As a first step, I would charge the battery overnight, then get it load tested.
You need to eliminate the battery first.
RonW
Newport Beach
« Reply #2 on: August 11, 2020, 02:00:11 PM »
If you have a multimeter, measure the volts (battery) at the very moment you press in the start button. Voltage shouldn't drop below 9.5 volts.
2000 Valkyrie Tourer
« Reply #3 on: August 11, 2020, 02:17:35 PM »
It could also be the starter button contacts. Go to shop talk and find the starter button maintenance.
« Reply #4 on: August 11, 2020, 02:51:28 PM »
This is my no 1 suspect
« Reply #5 on: August 11, 2020, 03:02:25 PM »
check battery. ICM needs a minimum of 10.5 volts when starter is turning to give a good start.  might start down to 9.5 volts bit not always.
WintrSol
Florissant, MO
« Reply #6 on: August 11, 2020, 03:08:49 PM »
I use a jump start battery; it will take a main battery fault out of the test, so if it still behaves the same, it's not the battery. If it starts fine, time for a ride to a battery store.
shadowmagic
« Reply #7 on: August 11, 2020, 03:24:20 PM »
ok, it doesnt happen all the time or very consistently yet. I would say about 1 out of every 5 or 6 starts. So I will start by charging the battery and measuring the voltage. Couldnt hurt to check the connections of the starter button. Thanks again everyone.
Madmike
Campbell River BC, Canada
« Reply #8 on: August 11, 2020, 04:24:22 PM »
If you havent done the start button mtce yet now is a good time, shouldn't do any harm, no real cost, may solve the issue and you will know its condition.
Check out your existing battery model #, the YTX14H-BS (Yaesu #) is a high output model of the YTX14-BS and gives better cranking power if you need to replace your battery, other manufacturers offer similar high output ones.
related - as mentioned below sometimes the engine will crank but not start because of low voltage, one thing I have noticed is that when cranking the engine the bike will start at the instant you release the start button, not sure if you get a voltage surge when you stop cranking or not.
