August 19, 2025, 03:33:08 PM
Rebuild carbs need help
Topic: Rebuild carbs need help (Read 1079 times)
jdp
August 11, 2020, 09:04:00 PM »
Hey everyone I let the gas sit in my bike too long and won’t run without the choke, I tried all the cleaners and all that and I just knew they had to come off, I tore into them and the problem I want to ask is when I counted the turns on the pilot screws I had one at 2 1/2 turns and the rest were 3 1/2 turns I know the book said 2 1/2 so should I put all of them at 2 1/2 turns or put them back the way they were ?
Re: Rebuild carbs need help
August 11, 2020, 09:21:16 PM »
I'm not a carb specialist, but I would start with the 2 1/2 turns first. Wait till you get it running, then see if any need adjusting.
Most likely they where at 3 1/2 because the carbs where a problem. Now fixed/cleaned, no more problem.
August 11, 2020, 10:20:55 PM »
The OEM manual says 2 turns out. Most valk run great set there. It’s become popular to open up more than that but it can bring MPGs down a bit.
yrunvs
Prior Lake, Minnesota
August 12, 2020, 04:50:50 AM »
I'd put them back just as I found them and see how it runs. Then if need be it's easy to adjust them later with the D tool.
I'm no gynecologist but hey I'll take a look!
August 12, 2020, 08:37:59 AM »
Quote from: yrunvs on August 12, 2020, 04:50:50 AM
I would set them all to 2, and then go from there.
August 12, 2020, 08:46:37 AM »
It all depends on what oil he is running
jdp
Reply #6 on:
August 27, 2020, 12:09:52 AM »
Thanks everyone for the help, I set them at 2 1/2 runs like a new bike runs so good I’m going to buy her something maybe a new windshield I can see threw
=> InZane XXV
