December 30, 2025, 06:20:37 PM *
Author Topic: Anyone ever heard of autokay before?  (Read 3507 times)
shadowmagic
« on: August 12, 2020, 06:54:57 AM »
So I always check amazon first because of my prime membership and lets face it, its just easy. I came across this kit and was wondering if anyone knows anything about it? It seems to have everything I would need but again I"m new to valkyries.
https://www.amazon.com/AUTOKAY-Carburetor-GL1500C-VALKYRIE-1997-2000/dp/B0876QTZK4/ref=sr_1_2?dchild=1&keywords=autokay+carburetor+rebuild+kit+honda+gl1500c&qid=1597240361&sr=8-2
« Reply #1 on: August 12, 2020, 07:21:36 AM »
That's a lot of stuff for a low price. OEM would be a lot more.
For $95 you could get the known-to-be-good red-eye kit.
https://redeye.ecrater.com/p/2063876/carburetor-gasket-kit-viton-gf
You'd still want bowl gaskets, he's got them. If you can clean
them, your old jets would probably be good. OEM jets cost a lot, you
hear negative remarks a lot from people who use other aftermarket
jets sometimes...
To me, removing/rebuilding/replacing the carburetors would be the
biggest part of the cost, and the part I most wouldn't want to
do over...
shadowmagic
« Reply #2 on: August 12, 2020, 07:29:55 AM »
That makes sense, I definately dont want to do this again anytime soon. So far I've spent more time working on this bike than riding it lol On the plus side, I'm actually beginning to enjoy working on it and I'm starting to have a good time learning all the little goods and bads that come along with it. This forum has been a blessing.
« Reply #3 on: August 12, 2020, 07:42:39 AM »
None of those parts are wear parts so you'd be replacing parts that don't need replacing.
Cleaning the orifices and passages in the carburetor are and should be the main objective.
And, a good regime of additive treatment should always be the first move.
Not to forget to mention that a comprehensive inspection should be the first course of action.
Preventive maintenance is the name of the game, "rebuild" is a misnomer and the refuge of the rookie.
shadowmagic
« Reply #4 on: August 12, 2020, 07:51:55 AM »
Hey, who you calling a rookie? I'll have you know I've had my valkyrie for a full 3 months already  Grin
« Reply #5 on: August 12, 2020, 08:36:41 AM »
Shocked that is a lot of stuff for dirt cheap. Made me think back to how proud I was about saving $300 on an alternator from Amazon a few years back. The first year, the drive nut came loose. The third year the bearings destructed on the way to Roanoke. (Don't even think about it, take Mike's advice)
shadowmagic
« Reply #6 on: August 12, 2020, 09:40:00 AM »
Yeah, I never against mike  Cool
vanagon40
Greenwood, IN
« Reply #7 on: August 12, 2020, 11:08:24 AM »
I have no idea of the quality of the AUTOKAY parts. But in general, I always try to remember:
Often attributed to Ben Franklin, but then so are a lot of other quotes.
Madmike
Campbell River BC, Canada
« Reply #8 on: August 12, 2020, 12:24:05 PM »
Google shows the trademark being owned by a Chinese company.
I would and have  gone with RedEye and K&L.  Redeye offers good known quality orings etc., test kit to prove the bowl seals things like that.
I have seen people say the springs on the float valves from K&L are higher force than stock whether this is true or not I do not know.  The float needles are common to several 250CC bike carbs.  Someone had posted a link to a 6 needle kit that was spec's for some of the 900CC bikes.
Here's a link https://www.klsupply.com/images/keihin-shop-float-needle-kit_App.pdf
« Reply #9 on: August 12, 2020, 03:21:07 PM »
There was a sign at my father's shop... "Marshall" in big nice
scrolley neon, and then hand lettering past that: "... signs
are made to last long after the price has been forgotten"
I still have the "Marshall"...
« Reply #10 on: August 12, 2020, 04:03:20 PM »
one experts view on float valves, dated 2015.   I don't know if this still holds true today for replacement.
https://www.randakksblog.com/more-problems-with-aftermarket-float-valves/
« Last Edit: August 12, 2020, 04:06:58 PM by 98valk » Logged
Timbo1
Tulsa, Ok.
« Reply #11 on: August 12, 2020, 07:14:55 PM »
I recently purchased a $60 complete carb rebuild kit from Ebay and found out that practically nothing was correct.  About the only things I was able to use were the pilot screw washers and o-rings.
All the jets were wrong size (main 130, Slow 42), needles wrong size, seals either to big or small or wrong thickness.
Sometimes it's just not worth the hassle to save a few bucks.  If you do go that route I'd suggest you ask them what size jets it comes with at the very least.  Best of luck
« Reply #12 on: August 12, 2020, 08:07:02 PM »
Does the neon still work ? Might look pretty good on the front of the new shed.  cooldude
« Last Edit: August 12, 2020, 08:13:32 PM by meathead » Logged
« Reply #13 on: August 13, 2020, 03:50:55 AM »
The neon sign has this scary 60 year old electrical igniter box that has kept
me from even trying to turn it on... for some reason he made this sign, maybe
testing out a new router? Ida know... anywho... I plan to put this on the front
of the shed:
Who knows where he got the idea?
Jims99
Ormond Beach Fl.
« Reply #14 on: August 13, 2020, 05:14:52 AM »
I have used the kit from allballs and so far no problems. $99 from Honda dealer. Bikes been running great for the past 6 months now. Came with everything in picture you showed. I bought it for the tourer but after rebuilding interstate carbs I still didn’t have the power I should. So pulled apart again and used the kit. Carbs looked great to start but the kit got it right. Now I need to get another one for the tourer.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
pancho
Bonanza Arkansas
« Reply #15 on: August 14, 2020, 07:19:51 AM »
of the shed:
Plug it in Mike, worst it can do is pop a breaker,,,  maybe release some noxious fumes. (i'd do it outside)            After all
"... signs
Good picture of dad
« Last Edit: August 14, 2020, 07:24:08 AM by pancho » Logged
