December 30, 2025, 06:20:39 PM *
Author Topic: Looks like I'm singing...  (Read 1344 times)
« on: August 13, 2020, 07:29:44 PM »
the alternator blues.  My high tech Battery Bug voltage and alternator monitor started barking at me today.  Battery is new this season and good.  I had recently given the ol' Bullet a rare real water wash.  I'm always careful with H2O around the alternator but I'm wondering if some got under the cover.  Anyway, I can see that with engine running the battery is not taking a charge.
Guess I'm going in.  I have two alternators, both used.  I'm thinking I'll gamble with one of them before springing on a new one.
I remember reading a thread fairly recently (this season?) here where someone moved the center panel out of the way a bit without having to fully remove it and said that made the alternator removal and installation much easier.  Of course I can't find it now.
I have manuals and know about removing the negative cable, etc..
Anyone have any other tips to make this maddening job easier?
« Last Edit: August 13, 2020, 07:44:50 PM by Valkorado » Logged
« Reply #1 on: August 13, 2020, 07:39:22 PM »
Did you check the 55A fusible link first?  If that’s blown you have no alternator.
« Reply #2 on: August 13, 2020, 08:20:40 PM »
I'll check it but the bike is starting and running fine, would it do so if that fuse was blown?
I know that the Battery Bug says around 13v when starting (I keep the batteries on a smart trickle pulse charger) but after I start the bike the Battery Bug shows 0% charging and the voltage starts dropping. It usually shows 14.2 - 14.4 when running.
« Reply #3 on: August 14, 2020, 05:19:02 AM »
Yes. It would start and run fine. But there would be no charging from the alternator
« Reply #4 on: August 14, 2020, 08:49:23 AM »
Thanks Jeff.  Checked the fusible, it was OK.  Unhooked the Battery Bug and rehooked to the battery.  It reset itself and shows a charge now.  I'm back in business!   cooldude
I'm singing a happy song now.
« Last Edit: August 14, 2020, 08:58:26 AM by Valkorado » Logged
« Reply #5 on: August 14, 2020, 08:18:12 PM »
Was this my post you where referring too?
http://www.valkyrieforum.com/bbs/index.php/topic,107156.0.html
Glad to hear it's working. Any idea why it would work after connecting to the battery? You had it connected to the alternator 1st?
« Reply #6 on: August 15, 2020, 05:57:30 AM »
I'd pulled the the leads from the battery posts a couple days earlier to set up some LED strips.  When reinstalling the Bug I didn't use proper sequence (positive then negative) which threw it outta whack.
I was prepping for alternator change.  I have that "dodged a bullet" feeling!
« Last Edit: August 16, 2020, 08:18:38 AM by Valkorado » Logged
