December 28, 2025, 05:31:47 AM *
Author Topic: Adding a Horn Relay to a '99 standard -- MD Tech  (Read 3386 times)
mello dude
Dayton Ohio
« on: August 14, 2020, 07:53:25 AM »
Hey - just some notes on a horn relay add on my standard, I know its old hat for a lot of you guys, but maybe it will help out others and give some ideas...
And I admit having a little fun posting this up...
I removed the stock horn long ago, and added this horn to try out.... but didnt wire it...
And went looking  for a round tuit for a couple years, and low and behold I found one last week...  Wink
Typically on a horn relay I refer to this diagram.... I never remember what wire goes to what number
on  a relay.....
So I grounded one lead on the horn and added a hot lead and routed it up by the steering head. And then also pulled the stock horn leads up by the steering head area...
For fuse, I am using a mini fuse holder and then for a relay, I am using this panasonic mini relay + base holder... available from cycleterminal.com
http://www.cycleterminal.com/accessory-relays.html
Its my "goto" place for wire em up stuff......
http://www.cycleterminal.com/index.html
Fuse holder....
And the relay + base
« Last Edit: September 20, 2020, 06:44:57 AM by mello dude » Logged
da prez
Wilmot Wi
« Reply #1 on: August 14, 2020, 08:02:57 AM »
Here is hoping the fuse is close to the power source. I have seen many a fuse at the end of the power run
            da prez
mello dude
Dayton Ohio
« Reply #2 on: August 14, 2020, 08:04:23 AM »
So the question on the relay and fuse holder is.... where are you gonna mount this stuff?
I fooled around with stuffing it in the steering head area, but nothiing there I liked, just too cramped.
So where? What about around the battery area? Where is the fuse gonna go?
Then the classic saying, " a bolt of lighting hits"  - Hey look at the battery box bolts. Maybe I could make a bracket to hold the fuse holder......
Hey, there's bracket in there somewhere....
Working it.....
Some more...
Now??
mello dude
Dayton Ohio
« Reply #3 on: August 14, 2020, 08:07:35 AM »
Hey, this could work.....
mello dude
Dayton Ohio
« Reply #4 on: August 14, 2020, 08:10:21 AM »
            da prez
Right on cue.... Yup - next to the battery.. I have lots of left over rotor bolts, and they sure are great for other spots...
Hey this can work!
Zip tie down the fuse holder to the bracket..
« Last Edit: August 15, 2020, 01:23:31 AM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #5 on: August 14, 2020, 08:15:32 AM »
So... now where is the relay gonna go? Hmmmmm
Well look at the other side of the battery box......
Maybe just zip tie it here?
Hey! Another bolt of lighting hits!  Cheesy
Oh, no way! A factory installed relay mount holder!
« Last Edit: August 14, 2020, 08:17:09 AM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #6 on: August 14, 2020, 08:27:00 AM »
Now, making progress, need to figure out a mini harness for it all....
Crimping terminals for the base holder block...
Getting the base block ready... Terminals are push to lock in.. easy.
« Last Edit: August 27, 2020, 03:38:40 PM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #7 on: August 14, 2020, 08:29:26 AM »
Figuring on the mini harness..
Using my specifically designed and engineered wire harness stand...  Wink
Ok, how is this thing gonna route up to the front?
« Last Edit: August 14, 2020, 09:28:10 AM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #8 on: August 14, 2020, 08:39:20 AM »
Snapped the base block and relay together and added a million yards of black electric tape...
mello dude
Dayton Ohio
« Reply #9 on: August 14, 2020, 08:41:53 AM »
Mini harness to the front starting to look good...
mello dude
Dayton Ohio
« Reply #10 on: August 14, 2020, 08:47:51 AM »
Working on the fuse connections......
As part of the deal, I replaced the radiator over flow hose with a higher quality Gates type hose,
its much stiffer than stock and worked out to be a good place for zip tying the pos leads down.
Cut a small slot for the eye terminal to connect to the battery...
« Last Edit: August 27, 2020, 03:17:17 PM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #11 on: August 14, 2020, 08:54:24 AM »
Back to the front, connected and marine heat shrink to it all.... Blue is the horn hot lead..
« Last Edit: August 27, 2020, 03:19:26 PM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #12 on: August 14, 2020, 08:57:48 AM »
Wrapping up final wire mini harness packaging...
Looking good...
Another million yards of black tape....
« Last Edit: August 14, 2020, 09:39:17 AM by mello dude » Logged
mello dude
Dayton Ohio
« Reply #13 on: August 14, 2020, 09:00:14 AM »
And finally - I'll take it...  cooldude
I like this kinda stuff, to be a little creative to get a job done.
Hope this helps out someone or gives a few ideas....
Cheers all
md  Cool
« Last Edit: August 14, 2020, 09:18:10 AM by mello dude » Logged
baldo
Youbetcha
Cape Cod, MA
« Reply #14 on: August 14, 2020, 07:22:19 PM »
MD, that's some fine wiring.....well done.
« Reply #15 on: August 14, 2020, 08:32:35 PM »
Beautiful job. All I did was take the hot horn wire, and used that as a trigger for the relay to power the horn.
http://www.valkyrieforum.com/bbs/index.php/topic,96578.0.html
(it might be far down)
mello dude
Dayton Ohio
« Reply #16 on: August 14, 2020, 09:44:57 PM »
Thanks, much appreciated  cooldude
Thanks too -- that's essentially what I have going on, but with more wiring work and following the diagram from the first post.
« Last Edit: August 14, 2020, 10:19:47 PM by mello dude » Logged
« Reply #17 on: August 14, 2020, 10:27:25 PM »
Great post!!!  cooldude
Do you make house calls???  Grin
mello dude
Dayton Ohio
« Reply #18 on: August 15, 2020, 01:51:23 AM »
Also thanks....
Geez, this forum needs a like button.... I'm on 5 or 6 other forums, all those have like buttons......
House calls? Ha ha....  Cool
« Last Edit: August 15, 2020, 02:00:29 AM by mello dude » Logged
Gondul
VRCC #408
Central Florida
« Reply #19 on: August 15, 2020, 04:05:19 PM »
This forum is a bit long in the tooth and can't do many things... like being to post pics without needing a photo hosting site.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
mello dude
Dayton Ohio
« Reply #20 on: August 15, 2020, 07:53:20 PM »
I use Smugmug. It's a pay site, but very good. Lots of great features, like being able to post any pic any size, thumbnail or gargantuan. Can setup folders for each gallery. And my page is mine alone - no one can interfere. I probably have 2500 photos saved there.  ...... No adds or pop-up junk goes on.
And they will never suddenly shut down... It's $69.95 a year (or around there). It's worth it.. Cool I'm a big fan...  cooldude
Agree about the site is loooong in the tooth, it needs a serious update....
« Last Edit: August 15, 2020, 09:35:01 PM by mello dude » Logged
Bone
« Reply #21 on: August 16, 2020, 02:12:11 AM »
Why doesn't anyone use photostash ? Guess I haven't been paying attention.
« Reply #22 on: August 18, 2020, 06:50:20 AM »
I stopped using it because I didn’t know how to avoid having to degrading my photos to get them to fit on photostash. The free hosting sites let me post a much better quality picture and its way easier
mello dude
Dayton Ohio
« Reply #23 on: August 22, 2020, 09:54:51 PM »
For the halibut... Smugmug.... Same photo
Tiny
Large - apparently there is a site pic post size restriction...
« Last Edit: August 22, 2020, 09:57:23 PM by mello dude » Logged
