December 30, 2025, 06:21:04 PM *
Author Topic: Ignition issue  (Read 1018 times)
Romeo
J.A.B.O.A.
Romeo, Michigan
« on: August 14, 2020, 12:21:34 PM »
Can someone help me with information on the pinouts for the B+ voltage to the ECM?
My diagram shows gnd at pin 14 and 12 Vdc pin4. The only place I see 12 volts is at what appears to be pin6, which I saw the input from the sidestand. I have 0 volts at pin4 which would explain my issue.
THe thing is Im not sure of how to count the pins either and see no indicators on the connector.
« Last Edit: August 15, 2020, 02:34:00 PM by Romeo » Logged
Madmike
Campbell River BC, Canada
« Reply #1 on: August 14, 2020, 10:04:28 PM »
My diagram shows god at pin 14 and 12 Vic at pin4. The only place I see 12 volts is at what appears to be pin6, which I saw the input from the sidestand. I have 0 volts at pin4 which would explain my issue.
#4 terminal shows as the common side of the coils in my schematics.  Which year and model of bike do you have and I can give you the wire colours if you want.
