November 13, 2025, 02:49:24 AM *
Author Topic: Driveline Maintenance at 175,000 miles  (Read 1162 times)
F6Dave
« on: August 16, 2020, 08:34:32 AM »
My '98 Tourer was ready for a new rear tire, so I finally replaced it yesterday.  It's been over 5 years since I last changed that tire as I don't ride this bike as much as the others.  The bike also will reach the 175K mark in less than 100 miles.  So I was very interested in seeing how the parts were holding up.
As you can see in the photo below, everything looked fine.  I'm sure these parts can last another 175,000 miles.  You might ask, do I use some special expensive grease on those drive splines?  Nope, just some wheel bearing grease from a can that's been in my garage for decades.  I like the sticky properties of that grease as it stays put, and also keeps the thrust washer where it belongs.  BTW that's the same thrust washer Honda installed in Marysville over 22 years ago.  The O-ring is original too.  The most important thing to keep the drive splines from failing is TORQUE THE AXLE NUT FIRST, before you tighten the 4 nuts holding the final drive to the swingarm.  If you do that, you could probably use WD-40 instead of grease and the splines would still last for a long time.
The only parts I worry about are the pinion and cup connecting the driveshaft to the final drive.  If your U-joint boot leaks, water can get in the cup and do severe damage.  Years ago, the service manager at a good Honda dealership showed me their method of keeping these parts lubricated.  Rather than trust that little oil hole in the pinion cup, they packed the cup with as much grease as they could get in there, intentionally clogging the hole and providing the parts with more dependable, superior lubrication.  The grease was nothing fancy, just a good multi purpose brand.  I've been using Mobil 1.  I've been following their advice ever since and it seems to be working.
« Last Edit: August 16, 2020, 08:37:51 AM by F6Dave » Logged
« Reply #1 on: August 16, 2020, 11:34:24 AM »
Everything looks great ! You are on the original o-ring on the hub ?  Shocked
dconstruct55
Phoenix AZ.
« Reply #2 on: August 16, 2020, 10:06:28 PM »
At 175k that looks great. What is your usual maintenance interval on the drive train?
F6Dave
« Reply #3 on: August 17, 2020, 05:57:13 AM »
Whenever I change the tire I do all the rest.  It's far easier then.
However, when the bike was new, I wasn't aware of all the drive train maintenance as it isn't listed on the charts in the manual.  So for nearly 40,000 miles when I changed a tire, all I did was replace the final drive oil and grease the drive splines.  I never touched the driveshaft, and more importantly I didn't loosen those 4 nuts, so the splines stayed in alignment.  I believe more damage is done to these bikes by improper maintenance of the drive train than if owners just left it alone.
« Last Edit: August 17, 2020, 07:02:46 AM by F6Dave » Logged
F6Dave
« Reply #4 on: August 17, 2020, 06:10:48 AM »
If it ain't broke...
I may replace them next time, but they still looked fine the other day.  Actually those o-rings are just one of many parts I've been wondering about.  There are dozens of rubber seals, boots, and o-rings on these 20 year old bikes that may need attention sooner or later.  Seals and o-rings shouldn't be a problem as they're just standard sizes.  But custom items like the driveshaft boot could get difficult to find at some point.  Luckily Honda has a great reputation for stocking service parts for decades.  BMW does that too.  I can still get just about any part I need for my 1988 R100 airhead, though I have to pay far more than Honda charges for similar parts.  For example, BMW wants about $250 for an ignition coil!
« Last Edit: August 17, 2020, 06:12:25 AM by F6Dave » Logged
dconstruct55
Phoenix AZ.
« Reply #5 on: August 20, 2020, 06:51:34 AM »
Thank you, great information!
