December 30, 2025, 06:20:29 PM *
Author Topic: What to look for when buying a Valkyrie  (Read 3344 times)
DSA
« on: August 16, 2020, 09:31:20 PM »
Hi there,
I've been lusting after a Valkyrie for some time now, and think I'm ready to start searching in earnest. There seem to be a fair few options out there, most of which have between 50k and 80k miles on them, and are in the $4-6k range.
Looking at the page on here that lists the members with the highest miles on their bikes, 80k (which would be a lot on pretty much any other bike) may actually not be very much for a valkyrie, correct? The goldwing also has a reputation for car-like longevity, and since it's a variant of the same engine, I'd guess it holds here, too.
Is there anything specific that I should be looking for? All of these bikes that I can see for sale appear to be well cared for and in good shape. As long as there are reasonable maintenance records, is there any cause for concern?
Thanks in advance, and looking forward to joining your ranks in the near future!
-DSA
shadowmagic
« Reply #1 on: August 16, 2020, 10:12:30 PM »
Mine had 20,000 miles on it. I've been chasing a backfire since I bought it. I would definately make sure and start it when its cold. Let it warm up and hold the throttle between 1500 and 2500 rpms and listen closely for backfiring. I'm new to valks also. The backfiring could be a lot of different issues as I'm finding out. Maybe inspect the rubber hoses around the carburators and ask if theyve been replaced. Ask about jetting if it has aftermarket parts. I would look into the gas tank for rust. Again, I'm definately not an expert on valks, this is stuff I wish I had been more thorough about when I bought mine. Oh, maybe ask if the valk has been sitting for any period of time and how long. Ask about carburator work ever being done like rebuilds.
« Reply #2 on: August 16, 2020, 11:59:59 PM »
Do you know which model you are after ? Standard, Tourer, Interstate. There was just an Interstate that was linked to on the Florida Chapter. $2000. General appearance will tell you a little of if maintainence was kept up. These bikes are pretty bullet proof. A lot of members will look at a bike that is nearby for you.
« Reply #3 on: August 17, 2020, 06:57:24 AM »
Here is a deal right here on the forum.
http://www.valkyrieforum.com/bbs/index.php/topic,112473.0.html
And another. Dont let the miles scare you on a well maintained valkyrie. I bet this one has been maintained properly.
http://www.valkyrieforum.com/bbs/index.php/topic,112493.0.html
« Last Edit: August 17, 2020, 06:59:58 AM by Bighead » Logged
txtriathlete
« Reply #4 on: August 17, 2020, 07:28:56 AM »
Hi there,
-DSA
As someone who buys and sells a lot of motorcycles (ok only 2 or 3 a year I guess) here's some things I look for:
Clean title and accurate history from the seller. Ask some questions. If they are "selling for a friend" or "my uncle who just moved out of state" etc. that's usually enough for me to walk away. You want to be able to talk with the owner/rider and be reasonably assured they will be around later if you have other questions. Example: I had a Valk standard that wouldn't start after I got it home. I contacted the seller only to find out that the kill switch on the grip had a short and he had not been using it to stop start the bike. Calling him saved me hours of trying to trouble shoot a problem on a new bike.
Other than that you want to be reasonably sure about maintenance, especially if its an older or higher mileage bike. I always ask who did the maintenance and ask very specific questions, like driveshaft maintenance and such. If they are legit they will know. BTW - if they haven't done it I don't necessarily walk away, I just approach the sale knowing I will have to do it. I have skills and tools to do stuff like that, YMMV. Just for fun - ask the owner where the air filter is and when they last changed it (its under the tank).
Valks have 6 carbs. The DO NOT like to sit for extended periods of time. Especially leaned over on the side stand. When they do, they get all sorts of nasty fuel problems. Carbs clogged, petcock leaks, fuel rail leaks. If it has been sitting for an extended period, you can bet you will be pulling the carb deck sooner rather than later.
Good used mileage on these is probably 30,000 to 60,000. Anything less and it's sat too much, more than that, well, there are folks on this board I might buy a high mileage valk from, but not a casual dude I meet from Craigs or FB. Also keep in mind that if you need to sell it for some reason, a higher mileage bike will be harder for you to sell as well. Most people won't understand it can go 250,000 on routine maintenance.
Pull the dipstick. Oil should be light brown or clear-ish. Dark brown or black means they haven't changed it in a while (shoddy maintenance), milky (like coffee w cream) means water in the oil - likely a bad head gasket or engine problem.
There may be a tiny amount of white smoke at start up from condensation in the exhaust, its ok. If it smokes a lot or keeps smoking, there's a problem. If it smells sweet, the head gasket is blown.
Check the fork seals, esp on higher mileage bikes or bikes that have sat a while. Easy repair but helpful to know if you'll need to do it.
Any aftermarket changes to air intake (other than a K&N filter) will require rejetting. Exhaust changes *may* require rejetting, if they significantly reduce the back pressure, like big truck stacks. The cobra 3 into 3 exhaust that's common do not usually require rejetting. If the bike HAS been rejetted, try to find out who did it and what jets they used. Carb work on these bikes can be tricky and not for the amateur mechanic.
They are fun bikes. The standards are scary fast and the interstates can run all day. IMHO the best of all is an IS with a Supervalk conversion, but then I may be biased...Smiley
Edit to Add: These bikes have an interference engine, which means if the timing belt goes, it will bend a valve and potentially ruin a piston. Belts on these are made to go a long way - 100,000 miles, but they may be 20 years old. Good idea to change the belts if you buy one, its cheap insurance and a reasonably easy maintenance item. There are also 2 belt idler pulleys that can go bad, they squeal or "sing" at operating RPM. I don't know if these are still available from Honda. I know the older Goldwing ones are unobtainium.
« Last Edit: August 17, 2020, 07:36:16 AM by txtriathlete » Logged
« Reply #5 on: August 17, 2020, 07:51:28 AM »
I know of 2 Interstates in the PHX area for sale. Both black. Contact me if you’re interested.
DSA
« Reply #6 on: August 17, 2020, 10:45:42 AM »
Thanks for the answers and the good suggestions! I live in Northern California. As to what I'm looking for, I think the sweet spot for me is a standard. I haven't always had the best luck with windshield - more often than not, they seem to buffet my head, and I'd prefer wind to the chest over that. Happy to play around with adding a windshield or Baker Wings in the future though.
Stock is good in my book. Pretty much all of the ones I'm looking at have had the wiring harness tapped into at some point to add heated grips and the like. Though hopefully they just ran something straight back to the battery and didn't make a mess of the wiring.
Good to know about the carbs. My experience is consistent with this - as long as the bike is regularly ridden, major carb overhauls can be avoided.
Will keep all this in mind, and go introduce myself as soon as I've sealed it!
~ Ron ~
It's the right thing to do
Ahwatukee, Arizona
« Reply #7 on: August 17, 2020, 11:32:56 AM »
My Standard is 20 years old and has 147,000 miles on it. these bikes will easily do 650,000 miles with 60,000 mile maintenance . 8,000 mile oil change.  I wish I had the room and the budget for a couple more....
~ Ron Pierce ~
~Ahwatukee, Arizona~
~VRCC 20050~
~TOI  27850 ~
~2000 Valkyrie / DFT ~
« Reply #8 on: August 17, 2020, 02:32:09 PM »
My Interstate has 127k miles and is a daily driver. It's never been messed with electrically and it runs perfectly. The whole life of the bike has been fueled with non-ethanol enriched gasoline and has never had anything remotely done to the carburetors. It's had a couple alternators with the last one installed only a few months ago.
Basically, all I've ever done is change oil, rear end service, and new brake pads, cam belts and new tires. plenty of tires.
I've never let anybody touch a tool to my bike and that's been the reason it's still running great.
If you want to see a picture of my Interstate you can see it in the for sale section of the forum.
da prez
Wilmot Wi
« Reply #9 on: August 17, 2020, 05:20:50 PM »
Ask the question to the board. Is there someone near to fingerprint the bike. Ask if unsure. Someone is close.
          da prez
« Reply #10 on: August 17, 2020, 07:58:16 PM »
Welcome, good first question.
Read the known Valkyrie issues in Shoptalk, so you know what to look for.
I would check out the colours/styles available, here.
http://www.valkyrienorway.com/About%20the%20Valk%20NEW.html
Then the manual here (and buy a paper copy too).
http://valkyrienorway.com/download.html
You can add your location to your profile, will help in the future.
I always recommend to new owners the following:
hydro lock
rear end service (ChrisJ has a write up in Shoptalk)
I'm sure I'm forgetting one other at least, but these can be very expensive repairs if you don't know about them.
