November 13, 2025, 04:53:53 AM *
Author Topic: Not allowing clock reset  (Read 1433 times)
99ISrdr
SC
« on: August 22, 2020, 05:21:23 PM »
Wondering if anyone's had a problem with the clock reset. Holding in clock button...no beep...therefore no hr/min adjustment. Wondering if it might be in the controller or in the wiring somewhere. The clock's running, just can't set the right time. Will just add or subtract if need be. Thanks in advance for any suggestions.
99 Interstate
09 Kawasaki Concours 14
F6Dave
« Reply #1 on: August 22, 2020, 08:06:20 PM »
Mine is finicky. Takes a lot of pressure on the button. There might be some corrosion on the contacts. Try setting it with the radio on, then with it off.
« Reply #2 on: August 22, 2020, 08:12:57 PM »
I would start with this thread, all apply.
http://www.valkyrieforum.com/bbs/index.php/topic,112767.0.html
99ISrdr
SC
« Reply #3 on: August 23, 2020, 06:29:30 AM »
Thanks for the suggestion. Tried it all, still not working. Might have to get under the fairing and check connections I guess.
99 Interstate
99ISrdr
SC
« Reply #4 on: August 23, 2020, 06:39:02 AM »
Thanks for the link. Looks like I'm going to have to chase it down somewhere in the wiring. Not much on electricals...we'll see where this ends up. Or....could be in the control unit...electrical problems...smh
99 Interstate
F6Dave
« Reply #5 on: August 23, 2020, 06:43:17 AM »
I'm curious if all the other radio functions work.  If they do, it may not be a simple cable issue.
I've noticed if I don't ride my Interstate for a while the clock gets very hard to reset.  That's why I suspect in my case corrosion builds up on that particular switch, as the button gets used so rarely.
« Last Edit: August 23, 2020, 06:46:11 AM by F6Dave » Logged
« Reply #6 on: August 23, 2020, 09:26:17 AM »
         Cycle the switches a LOT. Spray in a bit of contact cleaner. We are talkin I/S here right? RIDE SAFE.
mrtlc
Elroy WI
« Reply #7 on: August 23, 2020, 09:28:24 AM »
Can you disconect the battery at 12:00 and reset that way?
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
« Reply #8 on: August 23, 2020, 09:37:01 AM »
Yep, same problem here occurs occasionally.
It's the switches on the handlebars.
They get crusty from non use.
I don't think gorilla force on them is a good option.
I sprayed them and started moving them all and eventually they all started to function again.
Everything's back to normal.
Praise Mother Honda.
« Reply #9 on: August 23, 2020, 05:20:28 PM »
Not WD40.
ridingron
Orlando
« Reply #10 on: August 23, 2020, 06:55:20 PM »
  Not WD40.
Why?
WD40 works and you don't have to worry about it attacking the plastic. I soak it with the red straw in one of the switch seam's opening. Work switch while squirting the WD40. Place a towel or rag to catch the overflow.
Moxxican
Moxee, Wa.
« Reply #11 on: August 23, 2020, 09:30:15 PM »
Mine doesn't work if I push the button in all the way. But if I hold it just short of all the way, I'll get the beep and can set it. Maybe try that.
Jims99
Ormond Beach Fl.
« Reply #12 on: August 24, 2020, 05:09:44 AM »
WD-40 is flammable and also doesn’t dry up. That will cause dirt to build up on where ever it is. Contact cleaners dry up like alcohol and won’t attract any dirt. I have used wd-40 on electrical items if I can wipe them down before use. The chance of fire is slim, but not taking any chances.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
-mike-
Germany
« Reply #13 on: August 24, 2020, 05:30:44 AM »
WD40 IS attacking certain plastics (like PS and PC), IS swelling some rubbers and has not even a little ingredient to clean any corroded copper/tin/silver contacts.
Read the WD40 safety sheet.
-mike-
99ISrdr
SC
« Reply #14 on: August 24, 2020, 06:27:42 AM »
Tried that hoping it would work. No go. Will try some contact spray. Thanks
99 Interstate
99ISrdr
SC
« Reply #15 on: August 24, 2020, 06:31:50 AM »
Appreciate all the input guys. Sounds like it could be in the controller...hope so, don't want to go chasing wires. I've got WD40 but no contact cleaner, will chase some down and give it a go. Thanks
99 Interstate
« Reply #16 on: August 24, 2020, 04:50:39 PM »
WD40 is a Water Displacement lubricant, that WILL dry up over time (try it on any squeaky door, and give it some time).
You can use it on the switch, to clean and loosen, I do it all the time. But I also have contact cleaner, and I use that after the switch is no longer dirty/binding, usually a while later, after the switch starts to give me trouble again (it's expensive).
« Last Edit: August 24, 2020, 04:54:36 PM by gordonv » Logged
99ISrdr
SC
« Reply #17 on: August 25, 2020, 03:26:58 PM »
Shot some contact cleaner in there and worked the switch really well and low and behold...it worked! So anybody having that problem...give it a shot. Thanks to all for the input.
99 Interstate
SCain
Rio Rancho, NM
« Reply #18 on: August 31, 2020, 11:21:35 AM »
I have had to open that housing and open up a few switches, clean and relube just like the starter button maintenance.
Steve
