November 13, 2025, 04:54:49 AM *
Author Topic: Exhaust brackets  (Read 1071 times)
TrapperAH1G
Toledo, WA
« on: September 01, 2020, 05:10:04 PM »
2000 standard.  Currently have Cobra 6x6 and looking to install stock pipes.  Do both sets of pipes use the same mounting bracket(s)?  Is it just "plug and play" between the 2 systems?
I don't have the stock pipes to look at, pics I have don't really show what I need to know.
« Reply #1 on: September 01, 2020, 05:15:31 PM »
Never had cobras but they have to use the same mounting point on the bike.
« Reply #2 on: September 01, 2020, 05:18:29 PM »
I had 6x6 (I suspect they where Cobra), and they use the same mounts.
da prez
Wilmot Wi
« Reply #3 on: September 01, 2020, 08:36:49 PM »
  I have a set of stock pipes for sale.  Was told they only have 4-7000 miles use.
                                                          da prez
« Reply #4 on: September 02, 2020, 07:43:38 AM »
The only difference is OEM pipes have permanent studs that go through the mounting brackets from the outside with nuts on the back side and Cobras have nuts welded in place so bolts go through the mount from the inside
