August 19, 2025, 08:17:35 PM *
Author Topic: Trans noise  (Read 2003 times)
SNARLEY.WING
« on: September 06, 2020, 12:56:36 PM »
Have noticed a noise whining noise in 3rd and 4th gear when in lower gears on windy roads or slow traffic when I go to 5th the noise goes away is this normal for the trans on these bikes or is a service or further inspection needed
klb
Hickory nc
« Reply #1 on: September 06, 2020, 01:17:15 PM »
It is normal. The straight cut gears are strong but noisy.
Both of mine have the transmission covers which makes
it whine louder especially in 3rd and 4th gear. When they
quit whining it's time to worry.
« Last Edit: September 06, 2020, 01:23:30 PM by klb » Logged
« Reply #2 on: September 06, 2020, 05:34:05 PM »
Spray the inside of those tranny covers with some regular undercoating and let dry over night. Helps to muffle the noise some.
jnicks01
Clinton, IN
« Reply #3 on: September 08, 2020, 05:19:22 AM »
I have the tranny covers and the full hanger covers.  I threw some thin dynamat type product on the insides.  It's amazing how much quieter it is.  Took just a medium size sheet that I got on amazon for a few bucks.
I want to scoop out your brains and eat your knowledge.
SNARLEY.WING
« Reply #4 on: September 10, 2020, 07:07:54 AM »
THANKS FOR THE INFO , JUST WANTED TO KEEP HER TIGHT , WHILE IM ON HERE WHAT OIL WOULD YOU RECOMMEND FOR THE BIKE I KNOW ITS A WET CLUTCH SYSTEM ?
jnicks01
Clinton, IN
« Reply #5 on: September 10, 2020, 07:28:26 AM »
Oh boy...  Honda GN4 is my choice.  Or Rotella T6.  Just go with one of those.  T6 is more readily available.
Bagger John - #3785
« Reply #6 on: September 10, 2020, 08:01:38 AM »
(Flounder)Oh Boy - an oil thread!(/Flounder)
Honda HP4 (non-moly), Golden Spectro Semi or Full Synthetic are what I've stuck with using in my Valkyries - and I've tried a number of different oils in 20 years/5 Valks of ownership. In my experience, they make the F6 shift very smoothly in comparison to others. Haven't tried Royal Purple or Motul (yet) but some people swear by them.
As far as whine...if you want whine, go find an old, serviceable cab unit EMD locomotive that's powered by a Roots-blown B-series 567 prime mover. Open the service door, step inside the engine bay near the alternator then have your buddy sitting in the engineer's seat put the throttle into Run-8.
You'll never complain about a Valkyrie motor again, assuming enough of your hearing is left.  Cheesy
« Reply #7 on: September 10, 2020, 09:09:11 AM »
If you want to quiet the tranny whine as much as possible, Amzoil motorcycle specific 10W40 works better than any other oil on earth (and may be the best bike oil on earth), but it is expensive.
I ran it for years, until I was priced out of it.
I'm sure the oil I use is more than adequate for good protection, and I'm used to the whine.
https://www.amsoil.com/p/10w-40-synthetic-metric-motorcycle-oil-mcf/?code=MCFQT-EA&gclid=EAIaIQobChMIl-ehi_ze6wIVDkWGCh1F-AFBEAQYASABEgLLR_D_BwE
Bagger John - #3785
« Reply #8 on: September 10, 2020, 10:16:33 AM »
I run it in both of my Concours 14s. Buttery smooth shifts.
« Reply #9 on: September 10, 2020, 10:52:03 AM »
Most important:
Ken aka Oil Burner
Mendon, MA
« Reply #10 on: September 10, 2020, 12:34:08 PM »
When I purchased my Valk, I had the same noise concerns. I tried Amsoil 10w40 MC oil and was impressed with the reduction in noise (no idea what the previous owner was using). I was more impressed with the improvement in shifting. I actually decided to become a dealer for Amsoil. Now, kind of like Frank's Red Hot, I use that #### in everything!
