August 19, 2025, 05:54:58 PM
Broken neutral safety switch
Topic: Broken neutral safety switch (Read 990 times)
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
September 09, 2020, 06:06:46 AM »
I think my neutral safety switch broke on my 99 Interstate. The green (N) light will not go out in any gear. I can get the bike to start and run. Do I just need to replace the switch or is there something else that has broken or need to be replace?
Thanks, Greg
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
Earl43P
Farmington, PA
Re: Broken neutral safety switch
September 09, 2020, 06:14:23 AM »
Shorted wire coming out of the front transmission cover?
The switch provides a ground path for the light so if its wire is pinched=light on.
Give that a good visual inspection.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
RonW
Newport Beach
September 09, 2020, 07:54:29 AM »
Sounds like the
clutch diode
here
went south. When it does the neutral light stays ON.
Last Edit: September 09, 2020, 08:10:27 AM by RonW
2000 Valkyrie Tourer
September 09, 2020, 07:20:34 PM »
Trying to think this through, would the bike run/drive if the neutral light is on?
I suppose it would run, even when you're in gear. This of course is a safety issue.
September 09, 2020, 07:53:43 PM »
Had that happen once. When riding in the rain. Once it dried out (2days later) it started working normally again.
=> InZane XXV
