March 20, 2026, 02:47:52 AM *
Author Topic: Finally Avon Cobra Chrome Tires  (Read 5757 times)
« on: September 19, 2020, 10:08:51 AM »
After well over 20,000 miles my front tire is close enough to the wear bars I can replace it. Two brand new Cobra Chrome tires goin on next week
The rear is still good for many miles but it’s technically the spare. So I cleaned up the main wheel and both will get changed out at once
« Last Edit: September 24, 2020, 03:53:14 PM by Chrisj CMA » Logged
« Reply #1 on: September 19, 2020, 10:26:48 AM »
It never happens for me, but getting two new ties at one time provides a wonderful riding experience.  cooldude
If I ever got 20K from a front, I'd have a heart attack.  On the Valk, I've never made 10K.
« Reply #2 on: September 19, 2020, 10:29:18 AM »
This will be the first time on this bike for me. I’m excited
« Reply #3 on: September 19, 2020, 11:00:45 AM »
« Reply #4 on: September 19, 2020, 11:04:22 AM »
And I would have one if I had to replace tires that often
h13man
Indiana NW Central Flatlands
« Reply #5 on: September 19, 2020, 08:03:04 PM »
I'm @ 16,000 on my front Cobra running balance beads. Best I got up to this point was 15,000 on BS Exedras w/o beads. This is usually when I change both but the rear Cobra is done @ 11,000 mi. Just put on the new rear BS night before last. I installed Redeye urethane shock bushings 5 yrs. ago and all were good except one on the RH lower shock. Its smashed and crumbling thus I contacted Rich Byrne and he's replacing the whole set for $5 shipping included. He mentioned that early production they had this issue from time to time. Replaced the rear pads, cleaned the coolant tank, and ordered a 12 oz. bag of beads from O'Reilly's.
FWIW I tried using a 45 degree valve stem on the rear for easier filling but it made it a worse situation by putting the end closer to the wheel thus back to 90 degree one. Would probably work on 1100 Spirit type wheels but a 1100 Sabre might have an issue as they are similar to a Valk's wheel.
« Last Edit: September 20, 2020, 06:50:55 AM by h13man » Logged
« Reply #6 on: September 20, 2020, 07:03:42 AM »
I truly believe the big difference in mileage is a regional thing. Areas where traction is more critical must have rough roads compared to areas that have straighter flatter roads. If I got less than 20,000 on either the front or the back it would be the first time. Well the D-206 original tires didn’t make 10,000 but Dunlop Elite then E-3 Dunlop’s and now Avon Cobra and Cobra Chrome have all delivered over 20,000 miles.
« Reply #7 on: September 24, 2020, 05:47:40 AM »
Stayed up late last night removing both wheels. Got the rear end service knocked out cleaned and greased everything. Wheels and tires loaded in the truck. Leaving to have them mounted in a bit here. It’s a rainy day so the test ride will have to wait but nothing better than pampering the fat gurl on a rainy day
h13man
« Reply #8 on: September 24, 2020, 09:01:56 AM »
Went and scuffed mine in last evening. Now that I'm running balance beads on both ends, this is smoothest she ever rode. Of course new tires always ride better but the front used Cobra and the new rear Exedra really making me feel a little giddy.  Grin This is the 1st. time trying to do my own swap which ended up coming off with my tool of choice, the ever so versatile Saw All. That being said off to my installer to mount it and dispose of the old tire for $23. H rated steel belted radials are no longer going to be attempted to be installed by this ole' curmudgeon.  Embarrassed
« Last Edit: September 24, 2020, 09:04:06 AM by h13man » Logged
mello dude
Dayton Ohio
« Reply #9 on: September 24, 2020, 12:43:05 PM »
Hi - can you give like a 4000 mark ride reports on the Avon's once you get there?
I think those are my next tire set.....
- a bit of a request... can you add Avon Chrome in your first post title? It helps on the bookmarks.
Thxz  Cool
« Last Edit: September 24, 2020, 12:46:00 PM by mello dude » Logged
« Reply #10 on: September 24, 2020, 01:08:46 PM »
Thxz  Cool
Ok I’ll post a pic today with zero mikes and then at 4,000 and then at 20,000
« Reply #11 on: September 24, 2020, 01:14:10 PM »
Both tires mounted and balanced for $20 each and now they are ready to roll. I guess the cobra bike just got a little more cobra.
I’ll add some pictures for mello dude right here in a minute
« Last Edit: September 24, 2020, 01:32:19 PM by Chrisj CMA » Logged
« Reply #12 on: September 24, 2020, 02:45:44 PM »
The rain let up enough to do a shake down ride. Boy Howdy the old girl can dance with her new shoes. And, they are much quieter than the old ones.  It’s like power steering. I’ll gradually work into leaning all the way so no unintentional sliding takes place. So far, I see them as an upgrade.
sixlow
St. Augustine, Fl.
« Reply #13 on: September 24, 2020, 03:11:21 PM »
Jeff, I think I see a greasy smudge inside the left exhaust tip !  Shocked  C'mon man  coolsmiley
« Reply #14 on: September 24, 2020, 03:34:49 PM »
I’ll go inspect. Lol
msb
Agassiz, BC Canada
« Reply #15 on: September 24, 2020, 05:39:43 PM »
My Avons will last through this season, I am hoping for some decent pricing on new Chromes sometime before I replace them before next Spring. There is no better riding feeling than having both front and rear tires brand spankin' new at the same time. I can remember only one time that I've replaced both tires on the Valk at the same time, and that was for my ride to Morgantown WV Inzane. That glorious feeling lasted for days before I got used to it.
'99 Red  & Black IS
mello dude
Dayton Ohio
« Reply #16 on: September 24, 2020, 06:39:34 PM »
Thanks Chris!  cooldude
« Reply #17 on: September 25, 2020, 07:46:03 AM »
Good catch. Small smudge I guess from putting the wheel on. Can’t have that right Shocked
« Last Edit: September 25, 2020, 07:52:21 AM by Chrisj CMA » Logged
« Reply #18 on: July 09, 2021, 08:45:29 AM »
Ok as requested. My cobra chrome tires have 5,000 mikes on them.
Avanti
Stoughton, Wisconsin
« Reply #19 on: July 09, 2021, 09:02:30 AM »
Is that a shadow line on the rear or a wear line?
« Reply #20 on: July 09, 2021, 09:08:26 AM »
It’s mostly a shadow. I just went and looked real close. There’s a faint hint of a flat spot starting but the lighting makes it look worse.
BTW. These tires still ride like a dream. Smooth, quiet and great traction wet or dry
Avanti
« Reply #21 on: July 09, 2021, 09:39:14 AM »
Yes, cobras are my favorite. If the saying “you get what you pay for” still holds true then these days you get a lot.
« Reply #22 on: August 01, 2022, 11:39:28 AM »
Ok y’all. Just happened to check the calendar. Yep the Avon Chromes are right at 10,000 miles now. Half way done and still look good
« Last Edit: August 01, 2022, 11:43:48 AM by Chrisj CMA » Logged
H*GLEG
Mid MO
« Reply #23 on: August 01, 2022, 01:18:26 PM »
I thought they were great, Rear lasted 8K.  Front had 10K.
Shifting into 6th
« Reply #24 on: February 06, 2023, 05:45:42 AM »
Well 12K is it for the rear. Took a 3” nail and plugging is not working. Was easily good for another 10K
« Last Edit: February 06, 2023, 05:48:47 AM by Chrisj CMA » Logged
« Reply #25 on: February 06, 2023, 05:54:45 AM »
Take that puppy off and repair from the inside! What tire pressures are you running? I’ve got a new front Cobra for my Valkyrie waiting to be mounted when the bike is running again.
Also what balance method are you using?
« Reply #26 on: February 06, 2023, 06:04:40 AM »
Ya. I was going to get it patched but Judy talked me into buying a new one. I use the normal stick on weights and 42lbs. 40 in the front
« Reply #27 on: February 06, 2023, 06:43:02 AM »
You could get it patched anyway and keep it as a standby.  (if the remaining tread is worth it)
Just as a part of randomness of life, I now happen to have both bikes with new tires at the same time (it's a miracle).   Grin   (well, 10K on one car tire is almost like new)
New Michelin CrossClimate2 (Grand Touring All-Season) on the other bike.
So far, this is a great tire.
« Last Edit: February 06, 2023, 06:46:31 AM by Jess from VA » Logged
Avanti
« Reply #28 on: February 06, 2023, 03:03:41 PM »
I found a 1/4 inch bolt in my rear tire on one of my trips in early 2022. I was able to plug it and finish my last 1100 miles home. Fortunately it did not leak. It is no longer on my bike even though it had a lot of tread left. I do not want to be thinking about my tires when I am traveling.
« Reply #29 on: February 06, 2023, 03:17:44 PM »
The car tire I just had swapped for the Michelin picked up a big nail at the last Roanoke VA Inzane.  I rode it home from Roanoke (4 hours) with the nail still in it (only added air once).
It was stringy plugged, glued and clipped by an expert (not me).  No inside patch; if you're going to take it off the bike and the wheel, you might as well go with a new tire.  That car tire had lots of good tread, and the nail/plug was nicely captured in the tread.  I rode that tire for 4 more years without a loss of pressure (other than temp changes and sitting) or any other trouble.  I paid real close attention to it for the first few months, then forgot about it.
4 years later, it still had decent tread, but it went in the shop for other work, and it was time for a new tire... and a rear end service.
« Last Edit: February 06, 2023, 03:20:03 PM by Jess from VA » Logged
« Reply #30 on: February 07, 2023, 02:02:18 PM »
Ok my bike is all back together. Spare wheel/tire installed. All new oil, grease, 0-rings. Even new rear brake pads and brake fluid. Splines still perfect but the dampeners were shot. Should be good for awhile now.
This drive train has right around 100,000 miles on them
« Last Edit: February 07, 2023, 06:25:57 PM by Chrisj CMA » Logged
« Reply #31 on: February 07, 2023, 02:13:43 PM »
Jeff, were those dampers OE rubber, or aftermarket polyurethane?
My poly dampers just disintegrated in both bikes, after about 12-13 years of good service.
« Reply #32 on: February 07, 2023, 02:33:30 PM »
They were OEM, the new kind previously only for interstates. But it’s all good I have a few sets on hand.
« Reply #33 on: February 07, 2023, 02:40:11 PM »
Nice looking tire.  What size are you running?
« Reply #34 on: February 07, 2023, 03:52:09 PM »
The regular 205 60.  I like them fat.
I may not get the 37K the Goodyear Assurance Tripletread (no longer made) gave, but I hope so.
« Reply #35 on: February 07, 2023, 03:52:54 PM »
RNFWP
"What color blue is that?"
Greenville, SC
« Reply #36 on: February 08, 2023, 06:46:41 AM »
I've done rear end service on my Valk quit a few times now, however, when I first started (2014) I found your slideshow on the shoptalk page and printed it out and used it like a manual. It was great with all the photos. I've since learned a couple more tricks to help with that task but I've always wanted to say thanks for taking the time to put that together and sharing it with the rest of us.
If you keep after that final drive like you have... it looks like it will last a lifetime.  cooldude
« Reply #37 on: February 08, 2023, 06:51:56 AM »
Thanks, and You’re welcome. It’s good to know that slide show is being so helpful
« Reply #38 on: September 19, 2024, 12:23:58 PM »
Ok so the rear is new but the front now has 17,250 miles. I took the picture of more left side than right because the left side wears more. I think there’s a good 5,000 miles left on this tire.
« Reply #39 on: September 19, 2024, 01:04:40 PM »
Wow, just checked the dates. Can that be correct, says I started this post four years ago?!?!  Seems like one or two. And…. That means I’m averaging just a little over 4,000 miles a year now. At one time I was doing 10,000 in a year.
