June 22, 2025, 12:08:01 AM *
Author Topic: Anyone have the CCS-100 cruise control servo not being used?  (Read 931 times)
« on: September 22, 2020, 01:21:18 PM »
I get so aggravated when I go on Ebay and ask for a motorcycle cruise control. All they list is a throttle lock which is NOT a cruise control. I have a new set of control switches for the cruise mentioned but don't have the servo itself. I don't need all the mounting hardware, I can fabricate that. I could pull if off the old bike and reinstall the entire system on the trike, a rather involved project but will do it if need be. If you have or know of a servo, give me a shout, I want to put one on the trike. All I have now is a throttle lock which are a dime a dozen.
bentwrench
Philadelphia,Pa.
« Reply #1 on: September 22, 2020, 03:36:46 PM »
Hey John,  Do you have one that stopped working? They need to have the soleniods cleaned out every now and then to keep working. Mine went almost 100k  before it needed  cleaning. QD electronic cleaner worked well in mine.
« Reply #2 on: September 22, 2020, 08:34:29 PM »
No, the one I have is mounted on the 2-wheel bike and I'd like to install a CC on the trike I just bought. All I need is the servo. I didn't want to remove the entire setup off the old bike and transfer it to the trike but will if I can't find a second servo. I'll be moving the tank over so guess it won't be that big a deal to go one step further and pull the airbox so I can remove the vacuum reservoir and the CC hook up.
