shadowsoftime
« on: September 23, 2020, 02:12:06 PM » |
A continuing thread. Received clutch slave cylinder. Waxed the Trike.
« Reply #1 on: September 23, 2020, 02:31:52 PM » |
Washed if. Waxed the paint.
« Reply #2 on: September 23, 2020, 02:48:54 PM » |
Just the paint. I wax everything. Prevents dirt from sticking and reduces the chance for corrosion
« Reply #3 on: September 23, 2020, 02:50:16 PM » |
I put the queens throne back on we’re going to dinner on the bike together woohoo
« Last Edit: September 23, 2020, 02:53:04 PM by Chrisj CMA »
« Reply #4 on: September 23, 2020, 02:53:47 PM » |
I did my daily peek up under with a flashlight to make sure the clutch fluid leak I thought I fixed once and fixed even more a second time has stayed fixed this time.
Never ask a geek 'Why?',just nod your head and slowly back away...  IBA# 22107 VRCC# 7976 VRCCDS# 226 1998 Valkyrie Standard 2008 Gold Wing Taxation is theft. μολὼν λαβέ
« Reply #5 on: September 23, 2020, 03:23:21 PM » |
replaced the 38 PJs with the OEM 35 PJs in 2 wks ago. she doesn't like the 35s as soon as the temp dropped below 60F.
so putting the 38s back in.
well this turned into more work than I expected.
the forward left carb gave me problems yrs ago with a frozen idle mixture screw. well this time the PJ froze up and then half of the screwdriver slot broke off trying to unscrew it. so I pulled the carbs and when I did I see the one thermostat housing pipe is leaking at 65k miles. Is that normal?? Luckily I have two new O-ring spares.
I will be adding an extension to the radiator heat shield to provide better coverage of this left front carb as the right front carb has. Since the left carb actually gets blasted by the radiator hot air flow.
« Last Edit: September 24, 2020, 08:37:02 PM by 98valk »
turtle254
« Reply #6 on: September 23, 2020, 03:44:55 PM » |
Are you taking the whole set out, or just lifting and taking bowl off with set in place?
« Reply #7 on: September 23, 2020, 04:13:18 PM » |
Are you taking the whole set out, or just lifting and taking bowl off with set in place? I lift and tilt the tank, remove the air box bolt and then raise each side I'm working on. I use an allen wrench and small angle ratcheting screwdriver with replaceable bits. been doing it this way for yrs. much easier after I de-smogged it. only issue I have is I cannot drain the bowls since I have a Dial-A-Jet system installed, so a little maneuvering of the bowl and catch container for the gas.
matt
« Reply #8 on: September 23, 2020, 04:31:11 PM » |
Don't want to hijack thread but was looking into dial a jet, do you think it was worth doing
Thanks, pm me if you prefer
Funbaldguy
« Reply #9 on: September 23, 2020, 05:14:29 PM » |
Just put on my new to me ultimate seat. Tomorrow I ride to work. I’m taking the back roads.
« Reply #10 on: September 23, 2020, 05:23:49 PM » |
PM sent.
« Reply #11 on: September 23, 2020, 05:28:28 PM » |
...and after a late Amazon delivery, I added a Gremlin bell...
msb
« Reply #12 on: September 23, 2020, 05:40:05 PM » |
You purchased it yourself? Gremlin bells only work if someone gets it for you
'99 Red & Black IS
« Reply #13 on: September 23, 2020, 05:44:42 PM » |
You purchased it yourself? Gremlin bells only work if someone gets it for you  I hinted to the spousal unit and the now adult spawn for a month, finally gave up and just bought it myself... Always heard they work no matter what, but the power's doubled if it's given as a gift.....
msb
« Reply #14 on: September 23, 2020, 05:47:21 PM » |
Have bought or done nothing to my Valkyrie today. Don't really have anything else I want to add to her after 19 years except maybe another coat of wax. I do need to do something soon though, as she's been a bit neglected the past couple of weeks as I ride and tinker with my new to me '78 GL1000, so I think I'll polish her wheels this weekend....and if the weather cooperates, take her on a good long ride.
'99 Red & Black IS
« Reply #15 on: September 23, 2020, 05:48:33 PM » |
In almost 20 years of Valk ownership, never waxed one..... So.... any recommendations as to which wax product one should use now that I have one I'm trying to make and keep pretty?
msb
« Reply #16 on: September 23, 2020, 05:51:29 PM » |
You purchased it yourself? Gremlin bells only work if someone gets it for you  I hinted to the spousal unit and the now adult spawn for a month, finally gave up and just bought it myself... Always heard they work no matter what, but the power's doubled if it's given as a gift..... OK then, just make sure you locate it on your bike as close to the ground as possible...so you get the maximum protection out of the 50% protection you'll get by purchasing it for yourself
'99 Red & Black IS
« Reply #17 on: September 23, 2020, 05:54:43 PM » |
You purchased it yourself? Gremlin bells only work if someone gets it for you  I hinted to the spousal unit and the now adult spawn for a month, finally gave up and just bought it myself... Always heard they work no matter what, but the power's doubled if it's given as a gift..... OK then, just make sure you locate it on your bike as close to the ground as possible...so you get the maximum protection out of the 50% protection you'll get by purchasing it for yourself  ...the spousal unit and I pay all bills outta a joint bank account, and I handle all bill paying..... I'll just designate that it was paid for outta her side of the joint account...
« Reply #18 on: September 23, 2020, 06:01:27 PM » |
just put about 50 miles on the red Valk
First trip to work on that bike in months
Perfect day for the lower windshield
msb
« Reply #19 on: September 23, 2020, 06:03:32 PM » |
You purchased it yourself? Gremlin bells only work if someone gets it for you  I hinted to the spousal unit and the now adult spawn for a month, finally gave up and just bought it myself... Always heard they work no matter what, but the power's doubled if it's given as a gift..... OK then, just make sure you locate it on your bike as close to the ground as possible...so you get the maximum protection out of the 50% protection you'll get by purchasing it for yourself  ...the spousal unit and I pay all bills outta a joint bank account, and I handle all bill paying..... I'll just designate that it was paid for outta her side of the joint account... There ya go, I knew a smart guy like you would figure it out  As to your question about wax, I have been using Mother's Brazilian Carnauba Wax (pictured in the centre of my cleaning products photo) for the past 10 years or so. It's kept my Valk lookin' like new even after over 200,000 km (with lots of washing in between).
'99 Red & Black IS
« Reply #20 on: September 23, 2020, 06:44:48 PM » |
shadowsoftime
« Reply #21 on: September 23, 2020, 07:45:51 PM » |
You purchased it yourself? Gremlin bells only work if someone gets it for you  I hinted to the spousal unit and the now adult spawn for a month, finally gave up and just bought it myself... Always heard they work no matter what, but the power's doubled if it's given as a gift..... pm, me, i will send you one.
Jack B
« Reply #22 on: September 24, 2020, 05:41:07 AM » |
Hmmm, where to start?  I'm no mechanic but I don't think those wheels will fit your Valkyrie
Let’s RIDE
h13man
Indiana NW Central Flatlands
« Reply #24 on: September 24, 2020, 06:23:53 AM » |
Replaced rear tire, installed balance beads, replaced brake pads front & rear, cleaned coolant tank, flushed front brake MC, replaced LH lower shock bushing and "dusted".  I made a homemade wooden lift adaptor out of oak 7/8" plank. Still needs some tweaking a little rear heavy but actually worked out pretty well. May still weld a steel version this winter.
J.Mencalice
« Reply #25 on: September 24, 2020, 10:56:47 AM » |
Gave it it's annual bath and shining up a couple of days ago. There's a small, local car show this weekend and I think that I may ride it up there and place a for sale sign on it to see if I get any inquiries.
« Reply #26 on: September 24, 2020, 11:03:58 AM » |
Hmmm, where to start?  I'm no mechanic but I don't think those wheels will fit your Valkyrie No but I’ll be all set if I ever have to go to a trike! I do have a spare set of wheels for my Valkyrie so all I have to do is swap them out on tire changes.
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #27 on: September 24, 2020, 11:13:34 AM » |
Added some new electrical trappings to mine, for selfish reasons.
New Gerbing jacket liner, pants liner, their Vanguard gloves
....but got California Heat sock liners
since the only size of Gerbing I can find online was 'Ballerina' size, instead of 13E.....and the person I spoke with at Gerbing seemed almost smug when he said they have "no plans" to have more in stock, until next riding season.
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
« Reply #28 on: September 24, 2020, 02:00:35 PM » |
Oh that's an easy one, I cut the plug off the intercom lead going to the passenger seat. Was too thick to pull up through the space between the fender and frame, I could have loosened or removed the battery box at the rear area but cutting it off was quicker with less messing...and frustration. I have all the pins needed to reconstruct but doubt I will since I'll have no passenger and can't say I'm interested in getting one. I need to remove the trunk so I have an open area to work on and clean the back end of the undercarriage on the trike. Turning into a PITA.
Gideon
« Reply #29 on: September 24, 2020, 04:25:46 PM » |
Change Oil & Oil Filter (Rotella T6, 5-40 Synthetic Oil and Purolator Pure One PL14610 Oil Filter). Drain Crankcase Breather Tube (*Dragon Drool). Install Chrome Oil Filter Cover ($1.79 Salt Shaker). Clean and polish to get ready for Bike, Car and Truck Show this Saturday.
But they that wait upon the Lord shall renew their strength; they shall mount up with wings as eagles; they shall run and not be weary; they shall walk, and not faint. Isaiah 40:31
mello dude
Dayton Ohio
« Reply #30 on: September 24, 2020, 06:41:47 PM » |
Lotsa work...
* There's someone in my head, but it's not me....... * Mr. Murphy was an optimist.... * There's a very fine line between Insanity and Genius..... * My get up and go, must have got up and went.....
mello dude
Dayton Ohio
« Reply #31 on: September 24, 2020, 06:43:31 PM » |
Hi can you take pictures of the R&R clutch slave job? I may need to do mine... thxz
« Reply #32 on: September 24, 2020, 06:52:04 PM » |
Hi can you take pictures of the R&R clutch slave job? I may need to do mine... thxz I'm a complete mechanical idiot, and other than not torquing down on the banjo bolts enough the first time around, even I could do it. It's tedious, a pain in the ass, but not too bad.... GOT to have a lift since the sidestand assembly HAS to come off, but otherwise just a tedious pain.....
« Last Edit: September 24, 2020, 06:58:26 PM by Serk »
mello dude
Dayton Ohio
« Reply #33 on: September 24, 2020, 07:06:54 PM » |
« Last Edit: September 24, 2020, 07:16:40 PM by mello dude »
« Reply #34 on: September 24, 2020, 07:59:13 PM » |
Hi can you take pictures of the R&R clutch slave job? I may need to do mine... thxz I'm a complete mechanical idiot, and other than not torquing down on the banjo bolts enough the first time around, even I could do it. It's tedious, a pain in the ass, but not too bad.... GOT to have a lift since the sidestand assembly HAS to come off, but otherwise just a tedious pain..... My bikes (Interstates with fore/aft guards) have been over on the guards a few times. Not on purpose, and not for long, and I never leaked anything (other than maybe a wet gas cap). I wonder if you only had a bit of gas in the tank you could lay the bike over on the guards to do that job? So you wouldn't have to work under the bike and over the jack and (my wood) adapter. Wouldn't that make it easier?
mello dude
Dayton Ohio
« Reply #35 on: September 24, 2020, 08:16:10 PM » |
Hi can you take pictures of the R&R clutch slave job? I may need to do mine... thxz I'm a complete mechanical idiot, and other than not torquing down on the banjo bolts enough the first time around, even I could do it. It's tedious, a pain in the ass, but not too bad.... GOT to have a lift since the sidestand assembly HAS to come off, but otherwise just a tedious pain..... My bikes (Interstates with fore/aft guards) have been over on the guards a few times. Not on purpose, and not for long, and I never leaked anything (other than maybe a wet gas cap). I wonder if you only had a bit of gas in the tank you could lay the bike over on the guards to do that job? So you wouldn't have to work under the bike and over the jack and (my wood) adapter. Wouldn't that make it easier? Not sure I would want to lean the bike on the engine guards.. I also have the wood adapter for the jack and its in the way of pulling the side stand. Doesnt sound fun...
« Reply #36 on: September 24, 2020, 08:34:14 PM » |
Leaning the bike over on the guards hurts nothing (if there are no leakdown problems during the time it takes to do the job). Pad the guards if you want (foam pipe insulation, or a piece of carpet).
It can hurt your back/shoulder getting it back up.
I might need to do this job too.
msb
« Reply #37 on: September 24, 2020, 09:07:11 PM » |
Lotsa work...  WOW!! Now that is pretty
'99 Red & Black IS
mello dude
Dayton Ohio
« Reply #38 on: September 24, 2020, 09:15:25 PM » |
^^^^^ Thanks!
Gideon
« Reply #39 on: September 25, 2020, 07:48:53 AM » |
Lotsa work...  Very nice! A lot of work and costly too, I am sure.
