March 25, 2026, 12:02:39 PM *
Author Topic: Do you torque all your fasteners?  (Read 814 times)
« on: September 24, 2020, 11:10:03 AM »
« Reply #1 on: September 24, 2020, 11:17:23 AM »
Had to send that to my son-in-law. I was mounting the front calipers on his I/S using a ratchet wrench and on both mounting bolts on each side I reached a point where I said "that feels about right." I believe it's 22 ft. lbs. He got out the torque wrench and checked me....and was surprised it was right on the mark. He'll get a chuckle out of the picture.  Wink
msb
Agassiz, BC Canada
« Reply #2 on: September 24, 2020, 11:30:01 AM »
lol...that's a good one Smiley
I've traditionally been a notorious Over-Tightener, so yes now that I'm doing more and more of my own work on my bikes I use a torque wrench. Better safe than sorry, especially on critical components or where broken bolts can cause a real PITA, like headers, etc.
'99 Red  & Black IS
« Reply #3 on: September 24, 2020, 11:36:57 AM »
I generally fart @ 120ft lbs
« Reply #4 on: September 24, 2020, 01:53:51 PM »
Strange....I've never needed a torque wrench for that. Geez....learn something new every day.  Cheesy
« Reply #5 on: September 24, 2020, 02:46:27 PM »
If when it fails or falls out it will wreck my day, I use a torque wrench.  If it's grade 8.8 or higher, there's a likelihood that it's a critical bolt, so should probably be torqued to spec.  The bigger it is, the less likely my calibrated elbow will be accurate.
When I was tightening the nut on a hitch ball, my torque wrench had me put way more torque on it than I would have by feel.
« Last Edit: September 25, 2020, 08:13:30 AM by Gryphon Rider » Logged
« Reply #6 on: September 24, 2020, 03:03:04 PM »
I use my torque wrench on the axle nuts and final drive nuts. That’s really about it. If I ever had to get into the motor. Definitely torque wrench on everything to spec.
Now saying that understand I have been wrenching on bikes for over 40 years and I have a pretty good feel for the torque setting. And I can tell by the size and function of the fastener about how tight it needs to be pretty close to the specs.
« Last Edit: September 24, 2020, 06:30:06 PM by Chrisj CMA » Logged
« Reply #7 on: September 24, 2020, 04:07:49 PM »
Only occasionally in the privacy of my own home.
Thanks for asking.
« Reply #8 on: September 24, 2020, 05:28:23 PM »
At the right times. Over 5 decades of doing this work, mostly full time, has calibrated my elbow fairly well.
« Reply #9 on: September 29, 2020, 09:05:19 PM »
on some parts say 80 ft lbs. of torque I tried tightening to that.  Unless my turn knob torque wrench I got at Harbor Freight is off,  I could not get it to torque all the way up to 80 unless I was on steroids.  I must be weak,  anyone else have issues torquing to 80 or so not having enough muscles on a regular torque wrench?
« Reply #10 on: September 30, 2020, 05:24:44 AM »
No problem. I have an older bar type. I have the opposite situation. I get to 80 on the rear axle and it seemed too easy. So I usually go to 85 or so. 72,000 miles on the current rear end and it’s still like new so it must be right enough
RP#62
Gilbert, AZ
« Reply #11 on: September 30, 2020, 12:37:49 PM »
It depends.  For cosmetic items, probably not.  If the consequence of the fastener backing out is catastrophic, probably so.  If there's a good chance I could over-torque it and wipe out the threads, probably so.
-RP
