March 25, 2026, 12:02:43 PM *
Author Topic: Ear buds vs Bluetooth speaker in helmet  (Read 1092 times)
NighthawkVTX
Gainesville, Fl
« on: September 27, 2020, 01:35:02 PM »
Just wondering if anyone has experience with either using bluetooth earbuds, or bluetooth speakers that are made to fit in helmets.
Just wondering if the sound is comparible ?
If at first you don't succeed, then perhaps skydiving isn't for you
« Reply #1 on: September 27, 2020, 02:09:55 PM »
I cannot attest to the sound from Bluetooth Speakers in the helmet.  I have never tired that.
I have used, in the distant past, regular speakers in my helmet from a good source with reported good sound quality (I had no way of personally measuring the quality).
Issues.  In the helmet speakers for audio (music, audio books) are suppressed by the wind noise from riding.  Even a quiet helmet will generate wind noise at speed. The way to reduce that wind noise is, for some, to wear ear plugs that reduce the sound level.  It might work.  Some say it does.
In the ear speakers with molded earplugs that fit your ear not only provide noise reduction, they also can provide high quality audio.
I have used the non molded in the ear speakers (ear phones) and they are ok but  just OK.  And yes they are less expensive than the other route.
The route I chose about 7 years ago was to use a product from Ear Inc.  Their current version is different form the original version I started using years back.  (see link for item).
https://earinc.com/product/iplugz-pro-sports-earphones-gen-i/
It requires that you go to a local audiologist and get an ear impression made.  Then you ship that impression off to Ear Inc to get your molded in the ear speakers.  And yes there is a cost involved.
The plus side is that they can be worn all day with no issues in fact I don't like to take them out when I stop because it means I have to put them back in.  I forget they are there most of the time.
The audio quality is excellent.
Down side, as I said the cost and the wire.
Many folks will say they get by with just the ear buds you press in your ear and those might work but I found they tended to come out if not inserted exactly right and provide little if any noise reduction.
Regarding Bluetooth in general.  My audio system on my bike is wired.  I guess I could switch to bluetooth but they I have to worry about pairing, losing pairing, having my wife paired to the same source, pairing any microphones for speaking, you get the picture.
On the Valk, I have just one wire for each of us which combines the audio from the GPS and the radar detector. No mics.
On the wing, same thing, one wire ties our helmets to the Autocom audio system which combines in the wing's audio, the GPS, and the radar detector.  A wire then connects the earphones to the helmet lead in and we have good audio for communication and listening.
Jersey mike
Brick,NJ
« Reply #2 on: September 27, 2020, 02:36:33 PM »
I have a modular Nolan with their N-Com system and it’s great.
The sound quality is very good even at highway speeds. It’s able to do phone connection also.
I haven’t engaged the phone option, the last thing I want when riding is phone calls.
I get about a 50’ radius for connectivity and somewhere around 8 hours of play time.
If I’m out for the day and stop for lunch or other activities, I’ll plug the helmet in for a recharge.
Installing it into the helmet was easy.
I have a very early version iTouch that holds my music and has no issues connecting.
The Nolan N-Com also has a built in FM antenna and will play radio, but reception is 6/10 except for the strongest of radio in the area.
AwesomeDad
TN
« Reply #3 on: September 27, 2020, 02:45:26 PM »
I currently use a pair of westones in ear headphones plugged into my cardo helmet system, only issues is keeping them in place when putting on the helmet. I may go with speakers to see which I prefer, I’d rather wear ear plugs if the speakers are loud enough but in the past they haven’t been at speed...
JJ
« Reply #4 on: September 27, 2020, 02:56:53 PM »
I have Sena SMH10's in my helmet and the one my wife would wear. Works with Bluetooth (VERY LONG RANGE - 900feet or more), works with Phones and I use mine with my Garmin Zumo 396 GPS. Audio quality isn't too bad up to about 70 MPH (we use open face helmets with faceshields) and the last time we tried it - the intercom also works. Wind noise can be a bother when you are going fast enough (even behind a tall windshield). I have used the foam earplugs (25-30 dB sound reduction) with some success, but you need to turn up the volume on the headset to hear them. When I'm riding around, the battery is good for 8-12 hours. If you could combine the electronics of the Sena with the molded in ear plugs - that would be the bomb !
Oldfishguy
central Minnesota
« Reply #5 on: September 27, 2020, 03:19:08 PM »
I ve used these for a few years now, paired to my phone.  Cheap, and good quality sound.  Although, I don’t think a set has made it a year yet with something failing on them.
https://www.amazon.com/dp/B07DXRQZ15/ref=dp_prsubs_2
Psychotic Bovine
New Haven, Indianner
« Reply #6 on: September 27, 2020, 04:22:15 PM »
I use a pair of Shure SE215 wired earbuds with Comply memory foam tips.  All day comfort, very good NRR, superb sound quality (even at highway speeds, the quality comes through).  Audio comes from a Zumo 450.  Sometimes I route the sound through a Lexin R6 communicator (when my brother and I are riding together.  The Lexin is an inexpensive 1000m communicator for bike to bike comm).
The only downside is that you have to be a little careful putting your helmet on so it doesn't dislodge the earbuds.
"I aim to misbehave."
