December 30, 2025, 06:20:34 PM *
Author Topic: For those with Velocity Stacks  (Read 1545 times)
pocket aces
Tampa, Fl
« on: September 29, 2020, 07:58:17 AM »
If you have a screen in yours what did you use?
For those with an Interstate Tank did you have to raise the front n back of the tank or only the front?
AwesomeDad
TN
« Reply #1 on: September 29, 2020, 12:26:23 PM »
There’s a post showing where to put the 1/4” rubber pieces to raise the tank to clear the stacks...
JJ
« Reply #2 on: September 30, 2020, 07:15:01 AM »
I got mine already installed. But I will tell what I know about them. Only the front of the tank is raised with a spacer, maybe 3/4". The frame rubber cushions have a split heater hose under them raising them up maybe a 1/4". I have removed any of the stacks to examine them, but they appear to be a thin foam backer with screen over the top.
« Reply #3 on: September 30, 2020, 08:43:29 AM »
Dusty
Mill Bay B.C.
« Reply #4 on: September 30, 2020, 04:58:04 PM »
 Spacers front and back. No hose underneath. I bought a piece of screen from a marine supply store and cut with  tin snips.
